Salta al contenuto principale
Sunbeam Mini Pie Maker FPSBPMM980 Disassembly
Cosa ti serve
  1. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 1, immagine 1 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 1, immagine 2 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 1, immagine 3 di 3
    • Open the pie maker.
    • Remove four 4 mm screws holding the crescent-shaped black plastic plate in place with a Phillips #1 screwdriver.
    • Remove the black crescent-shaped plastic plate.
  2. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 2, immagine 1 di 2 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 2, immagine 2 di 2
    • Repeat the previous step to remove the upper black crescent-shaped plastic plate from the upper half of the unit.
    • The pie maker's symmetrical construction may cause confusion—in this image the pie maker is resting on its upper half.
  3. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 3, immagine 1 di 1
    • Remove the four 4 mm screws located directly on either side of the hinges with a Phillips #1 screwdriver.
    • Successfully removed screws will allow for the separation of the pan component from the outer plastic shell.
  4. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 4, immagine 1 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 4, immagine 2 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 4, immagine 3 di 3
    • Remove the final two 4 mm screws from the circular black plastic bottom base plate with a Phillips #1 screwdriver.
    • Remove the black plastic base.
  5. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 5, immagine 1 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 5, immagine 2 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 5, immagine 3 di 3
    • Disconnect the two red and green incandescent lights from their fixtures by popping them out of their red plastic cradles.
  6. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 6, immagine 1 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 6, immagine 2 di 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 6, immagine 3 di 3
    • Examine successfully disassembled Sunbeam Mini Pie Maker FPSBPMM980.
    • If desired, remove insulatory coated paper cut outs to more easily access heating coils.
  7. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: passo 7, immagine 1 di 1
    • Examine electronics schematic.
    • The Sunbeam Pie Maker utilizes four heating coils to bring miniature pies to an internal temperature of 175+ F. The pies are placed in the appliance after pre-heating, and are cooked for approximately 10 minutes, or until golden brown. The machine begins pre-heating upon being plugged in, signifying it is receiving power with the red light.
Conclusione
To reassemble your device, follow these instructions in reverse order. Happy fixing!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 125
