Introduzione
Use this guide to replace a broken or damaged hand strap.
Parti
Nessuna parte richiesta.
Place the lamp LED side down on a clean workspace.
  • Place the lamp LED side down on a clean workspace.
  • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
Aggiungi Commento
Gently pull the two halves of the lamp apart.
  • Gently pull the two halves of the lamp apart.
Aggiungi Commento
  • Remove both ends of the strap from the orange casing by pulling up.
Aggiungi Commento
  • Insert the ends of the new strap into the strap housing on both sides of the orange component.
  • Either strap housing (inner or outer) can be used to adjust the strap length.
Aggiungi Commento
Conclusione
Anna
Membro da: 23/10/2014
454 Reputazione
4 Guide realizzate
Michigan Tech, Team 1-3, Lauer Fall 2014 Membro di Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 74
