Salta al contenuto principale
Summer LookOut Duo Navigation Buttons Replacement
Cosa ti serve
  1. Summer LookOut Duo Navigation Buttons Replacement, Battery: passo 1, immagine 1 di 3 Summer LookOut Duo Navigation Buttons Replacement, Battery: passo 1, immagine 2 di 3 Summer LookOut Duo Navigation Buttons Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the device over so the back is facing up.
    • Remove the 9 mm screw using a Phillips #1 screwdriver.
    • Lift the battery panel away from the device.
  2. Summer LookOut Duo Navigation Buttons Replacement: passo 2, immagine 1 di 3 Summer LookOut Duo Navigation Buttons Replacement: passo 2, immagine 2 di 3 Summer LookOut Duo Navigation Buttons Replacement: passo 2, immagine 3 di 3
    • Flip the handheld monitor over and let the battery fall out into your hand.
    • Using angled tweezers, gently remove the plastic wire coupling from the side of the open battery compartment.
    • If the coupling struggles to release, with a loose but firm grip, slightly wiggle the plastic wire coupling back and forth until it releases.
    • Remove the battery from the device.
  3. Summer LookOut Duo Navigation Buttons Replacement, Motherboard and Display: passo 3, immagine 1 di 3 Summer LookOut Duo Navigation Buttons Replacement, Motherboard and Display: passo 3, immagine 2 di 3 Summer LookOut Duo Navigation Buttons Replacement, Motherboard and Display: passo 3, immagine 3 di 3
    • Using the Phillips #00 screwdriver, remove the four 7mm screws from each corner on the back of the handheld monitor.
    • Remove the casing from the back of the handheld monitor.
    • A nylon spudger may be helpful to pry the case open.
    • Using the angled tweezers, gently remove the plastic wire coupling connecting the speaker to the motherboard.
    • The power button may come loose as the case is being removed.
  4. Summer LookOut Duo Navigation Buttons Replacement: passo 4, immagine 1 di 2 Summer LookOut Duo Navigation Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the motherboard and monitor display together and set aside.
  5. Summer LookOut Duo Navigation Buttons Replacement, Navigation Buttons: passo 5, immagine 1 di 2 Summer LookOut Duo Navigation Buttons Replacement, Navigation Buttons: passo 5, immagine 2 di 2
    • Gently remove the black foam padding from the back of the buttons.
    • Using your fingers, gently lift the navigation buttons from the front monitor casing.
    • There are two sets of buttons: the outer navigation ring and the inner menu button.
    • The buttons are not fixed in place and will readily push out of the case. Use light force to prevent loss.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 83
