Salta al contenuto principale
Summer 3D Lite Convenience Stroller Front Wheel Replacement
Cosa ti serve
  1. Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: passo 1, immagine 1 di 2 Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: passo 1, immagine 2 di 2
    • Locate the black plastic tabs on the front wheel. There should be two, opposite sides from each other.
  2. Summer 3D Lite Convenience Stroller Front Wheel Replacement: passo 2, immagine 1 di 2 Summer 3D Lite Convenience Stroller Front Wheel Replacement: passo 2, immagine 2 di 2
    • Firmly press both tabs inwards, and use your other hand to pull the wheel off
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team 11-5, Forte Fall 2015 Membro di Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Membri
4 Guide realizzate
16Commenti sulla guida
How can i order the front wheels
Amalia Ontiveros - Replica Condividi
Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST.
Stroller Guy - Condividi
I think there should be a video tutorial for this product. thank you!!
Lisa D. Richards - Replica Condividi
Yes i think there should be a video
yummy mummy fantom XXX - Condividi
The Front wheel is less bending in the axis, how to make straight by hand
Samson Wong - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 206
Tutti i Tempi: 62,083
