Introduzione
Use this guide to replace your back wheel on your Summer Infant 3D Lite stroller.
Set the stroller up so the front wheel is on the ground with the metal push tab up.
OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
My tabs are stuck inside now I used the key and wheel isn't coming off
Hi, same has happened with me. How did you resolve this issue?
This tip has been very useful. Thank you! I used a screw driver instead of a key to push the tab down and it came out easily.
Altre 4 persone hanno completato questa guida.
2 Commenti
Gd, have a question . Were can u buy spare parts for this type of stroller?
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
