Salta al contenuto principale
Stuck Shutter Fix Replacement
  1. Stuck Shutter Fix  Replacement, Shutter: passo 1, immagine 1 di 1
    • Put the camera in any mode other than Auto, and turn off the flash.
    • Turn off the LCD screen and press the DISP or DISPLAY button.
  2. Stuck Shutter Fix  Replacement, Adjust the Camera Setting: passo 2, immagine 1 di 1
    • For many canon cameras this will be shutter priority mode, that will give you the longest exposure time without flash.
  3. Stuck Shutter Fix  Replacement, Open/Close the Battery Door: passo 3, immagine 1 di 1
    • After a few seconds open the battery door then close it again. This will momentarily interrupt power during the exposure time.
    • Repeat the procedure until the shutter becomes unstuck.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 122
Tutti i Tempi: 6,733
