Salta al contenuto principale
Stihl O25 Chain Replacement
Cosa ti serve
  1. Stihl O25 Chain Replacement, Stihl O25 Chain: passo 1, immagine 1 di 1
    • Be sure to turn off the chainsaw before servicing it.
    • Caution: Chainsaw blades are sharp. Wear protective gloves through the procedure.
    • Loosen the nuts on the chain cover with the wrench side of the scrench until the cover comes off of the saw.
    Chiedi a FixBot
    Aggiungi Commento
  2. Stihl O25 Chain Replacement: passo 2, immagine 1 di 1
    • Pull the chain and chainsaw bar off of the power head.
    • Pull the chain back to loosen off of the gears, and lift straight up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Stihl O25 Chain Replacement: passo 3, immagine 1 di 1
    • Clean out the grooves on the chainsaw bar. This will help with the next step.
    Chiedi a FixBot
    Aggiungi Commento
  4. Stihl O25 Chain Replacement: passo 4, immagine 1 di 1
    • Make sure the chain is positioned correctly. If you are looking at the top of the saw, the chain rotates away from the operator.
    • Position the chain so the teeth face away on the top of the saw.
    Chiedi a FixBot
    Aggiungi Commento
  5. Stihl O25 Chain Replacement: passo 5, immagine 1 di 1
    • Place the bar and chain back onto the saw.
    • The bolt slot on the bar will slide onto the bolts on the saw.
    • The chain will go around the gear towards the back of the saw.
    • You may have to move the chain around to get it to fit properly.
    Chiedi a FixBot
    Aggiungi Commento
  6. Stihl O25 Chain Replacement: passo 6, immagine 1 di 2 Stihl O25 Chain Replacement: passo 6, immagine 2 di 2
    • Tighten the chain by turning the tightening screw.
    • Insert the screwdriver end of the scrench into the screw and turn clockwise.
    Chiedi a FixBot
    Aggiungi Commento
  7. Stihl O25 Chain Replacement: passo 7, immagine 1 di 1
    • Chain tightness is often a preference of the chainsaw operator, but a good rule of thumb to follow is when you pull up on the chain, two chain links should come out of the bar grooves.
    Chiedi a FixBot
    Aggiungi Commento
  8. Stihl O25 Chain Replacement: passo 8, immagine 1 di 1
    • Put the cover back on and tighten the nuts down.
    Chiedi a FixBot
    Aggiungi Commento
  9. Stihl O25 Chain Replacement: passo 9, immagine 1 di 1
    • To sharpen the chain, mark one of the teeth with a pencil or sharpie.
    Chiedi a FixBot
    Aggiungi Commento
  10. Stihl O25 Chain Replacement: passo 10, immagine 1 di 1
    • Take a round file and place it on the cutting surface.
    Chiedi a FixBot
    Aggiungi Commento
  11. Stihl O25 Chain Replacement: passo 11, immagine 1 di 1
    • The file should be angled slighty upwards and follow the angle of the saw tooth.
    • Slide the file while applying pressure and twist slightly.
    Chiedi a FixBot
    Aggiungi Commento
    • Teeth on a saw alternate which way they are facing.
    • Skip one tooth to continue to sharpen on the same side. Use the same number of file strokes on each tooth.
    • Continue to sharpen until you reach the original tooth that was marked. You can then sharpen the set of teeth facing the other way with the same process.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Nathan Comar
Membro da: 03/30/16
209 Reputazione
Una guida realizzata
Michigan Tech, Team 1-3, Lauer Spring 2016 Membro di Michigan Tech, Team 1-3, Lauer Spring 2016
MTU-LAUER-S16S1G3
Membro di 1
1 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 16
Ultimi 30 giorni: 74
Tutti i Tempi: 2,443
