Salta al contenuto principale
Steelseries Rival 3 Scroll Wheel Replacement
Cosa ti serve
  1. Steelseries Rival 3 Scroll Wheel Replacement, Scroll Wheel: passo 1, immagine 1 di 1
    • Disconnect the mouse from your laptop/personal computer.
  2. Steelseries Rival 3 Scroll Wheel Replacement: passo 2, immagine 1 di 2 Steelseries Rival 3 Scroll Wheel Replacement: passo 2, immagine 2 di 2
    • Remove the three mouse skates with a prying tool.
    • Your prying tool may slip when removing the skates so proceed with caution.
    • If new skates are needed, purchase them at SteelSeries Rival 3 Mouse Skates.
  3. Steelseries Rival 3 Scroll Wheel Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the four screws from the base of the mouse and remove the casing.
  4. Steelseries Rival 3 Scroll Wheel Replacement: passo 4, immagine 1 di 1
    • Remove the wire that is connected to the circuit board of the mouse as shown in the image.
    • The wire and the socket can be damaged if not handled with care.
  5. Steelseries Rival 3 Scroll Wheel Replacement: passo 5, immagine 1 di 1
    • Carefully take off the circuit board and lay it on the surface being used.
    • Be careful when doing so to prevent the wire connected to the base of the mouse from breaking.
  6. Steelseries Rival 3 Scroll Wheel Replacement: passo 6, immagine 1 di 2 Steelseries Rival 3 Scroll Wheel Replacement: passo 6, immagine 2 di 2
    • Remove the four black screws along the circuit board using a Phillips #0 screwdriver.
  7. Steelseries Rival 3 Scroll Wheel Replacement: passo 7, immagine 1 di 1
    • Remove the scroll wheel by taking it out of its socket.
    • The socket is the silver tower that allows the mouse to turn while keeping the scroll wheel stiff.
  8. Steelseries Rival 3 Scroll Wheel Replacement: passo 8, immagine 1 di 1
    • Insert your new scroll wheel into the tower where the scroll wheel was originally.
    • Ensure not to apply excessive force during the process.
    • Before you put the mouse back together, make sure the scroll wheel turns smoothly in order for the mouse to work.
Conclusione
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
in need help there i no place i can find that actually has the right one please help
Wynter Merritt - Replica Condividi
you can't find the part? because i just found one on aliexpress for 5 dollars..
unless ur in a diff country, in which case tell me where and ill see if i can help you
hellonearth311 - Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 75
Ultimi 30 Giorni: 419
Tutti i Tempi: 8,116
