Salta al contenuto principale
SteelSeries Arctis Pro Microphone Cable Replacement
Cosa ti serve
  1. SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: passo 1, immagine 1 di 2 SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: passo 1, immagine 2 di 2
    • Remove ear cushion by pulling the cushion up and towards yourself.
    • Repeat this motion around the cushion until it comes free.
  2. SteelSeries Arctis Pro Microphone Cable Replacement: passo 2, immagine 1 di 2 SteelSeries Arctis Pro Microphone Cable Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the 3 case screws.
    • Lift the driver assembly away from the rest of the housing.
  3. SteelSeries Arctis Pro Microphone Cable Replacement: passo 3, immagine 1 di 3 SteelSeries Arctis Pro Microphone Cable Replacement: passo 3, immagine 2 di 3 SteelSeries Arctis Pro Microphone Cable Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
    • Push the headset volume dial in-words towards the housing while simultaneously pulling the board towards yourself.
  4. SteelSeries Arctis Pro Microphone Cable Replacement: passo 4, immagine 1 di 1
    • De-solder the six connections on the side of the main board.
  5. SteelSeries Arctis Pro Microphone Cable Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws that secure the microphone holder.
  6. SteelSeries Arctis Pro Microphone Cable Replacement: passo 6, immagine 1 di 3 SteelSeries Arctis Pro Microphone Cable Replacement: passo 6, immagine 2 di 3 SteelSeries Arctis Pro Microphone Cable Replacement: passo 6, immagine 3 di 3
    • Pull the microphone assembly and cable out of the housing and out towards you until it comes free.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 68
Tutti i Tempi: 1,148
