Salta al contenuto principale
SteelSeries Arctis Pro Headset Mute Button Cap Replacement
Cosa ti serve
  1. SteelSeries Arctis Pro Headset Mute Button Cap Replacement, Headset Mute Button Cap: passo 1, immagine 1 di 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement, Headset Mute Button Cap: passo 1, immagine 2 di 2
    • Remove the ear cushion by pulling the edge up and towards yourself
    • Repeat this motion all the way around the ear cushion until it comes free
  2. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 2, immagine 1 di 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the 3 case screws.
    • Remove the driver assembly from the rest of the housing
  3. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
  4. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 4, immagine 1 di 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 4, immagine 2 di 2
    • Remove the circuit board by pushing the scroll wheel out of the board and pulling it from the other side.
  5. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 5, immagine 1 di 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 5, immagine 2 di 2
    • Grab the keycap and pull outwards till it comes free
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 46
Tutti i Tempi: 927
