Salta al contenuto principale
SteelSeries Apex 64145 USB Port Connector Replacement
Cosa ti serve
  1. SteelSeries Apex 64145 USB Port Connector Replacement, Gel Membrane: passo 1, immagine 1 di 1
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 USB Port Connector Replacement: passo 2, immagine 1 di 1
    • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
  3. SteelSeries Apex 64145 USB Port Connector Replacement: passo 3, immagine 1 di 1
    • Pry open the back of the keyboard.
  4. SteelSeries Apex 64145 USB Port Connector Replacement: passo 4, immagine 1 di 2 SteelSeries Apex 64145 USB Port Connector Replacement: passo 4, immagine 2 di 2
    • Remove the gel membrane.
  5. SteelSeries Apex 64145 USB Port Connector Replacement, LED: passo 5, immagine 1 di 2 SteelSeries Apex 64145 USB Port Connector Replacement, LED: passo 5, immagine 2 di 2
    • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
  6. SteelSeries Apex 64145 USB Port Connector Replacement: passo 6, immagine 1 di 1
    • Flip the chip slightly in order to remove the sheets.
  7. SteelSeries Apex 64145 USB Port Connector Replacement: passo 7, immagine 1 di 1
    • Remove the sheets.
  8. SteelSeries Apex 64145 USB Port Connector Replacement: passo 8, immagine 1 di 2 SteelSeries Apex 64145 USB Port Connector Replacement: passo 8, immagine 2 di 2
    • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
  9. SteelSeries Apex 64145 USB Port Connector Replacement: passo 9, immagine 1 di 1
    • Remove the plastic panel and the white sheet.
  10. SteelSeries Apex 64145 USB Port Connector Replacement: passo 10, immagine 1 di 3 SteelSeries Apex 64145 USB Port Connector Replacement: passo 10, immagine 2 di 3 SteelSeries Apex 64145 USB Port Connector Replacement: passo 10, immagine 3 di 3
    • Unplug the wires connected to the LEDs.
  11. SteelSeries Apex 64145 USB Port Connector Replacement: passo 11, immagine 1 di 2 SteelSeries Apex 64145 USB Port Connector Replacement: passo 11, immagine 2 di 2
    • Remove the LEDs.
  12. SteelSeries Apex 64145 USB Port Connector Replacement, USB Port Connector: passo 12, immagine 1 di 1
    • Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
  13. SteelSeries Apex 64145 USB Port Connector Replacement: passo 13, immagine 1 di 1
    • Unplug the wires and remove the USB port connector.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G1, Nance Spring 2017 Membro di USF Tampa, Team S1-G1, Nance Spring 2017
USFT-NANCE-S17S1G1
4 Membri
10 Guide realizzate
2 Commenti
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
Simon Sundström - Replica
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
Twsted - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 51
Tutti i Tempi: 3,030
