Salta al contenuto principale
SteelSeries Apex 64145 Key Replacement
Cosa ti serve
  1. SteelSeries Apex 64145 Key Replacement, Key: passo 1, immagine 1 di 1
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 Key Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool underneath the edge of the key.
  3. SteelSeries Apex 64145 Key Replacement: passo 3, immagine 1 di 2 SteelSeries Apex 64145 Key Replacement: passo 3, immagine 2 di 2
    • Gently pry the damaged key with the plastic opening tool at an upward angle.
  4. SteelSeries Apex 64145 Key Replacement: passo 4, immagine 1 di 1
    • If replacing, prepare your new key for insertion.
    • If key is dirty, wash the key with room temperature water and dry off the key with a towel.
  5. SteelSeries Apex 64145 Key Replacement: passo 5, immagine 1 di 1
    • Gently push the key back into the slot until you hear a click.
Conclusione
USF Tampa, Team S1-G1, Nance Spring 2017 Membro di USF Tampa, Team S1-G1, Nance Spring 2017
USFT-NANCE-S17S1G1
4 Membri
10 Guide realizzate
Un commento
very easy… if u can find new keycap. those are customs not sold
T T - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 45
Tutti i Tempi: 5,418
