Salta al contenuto principale
Steam Link Disassembly
Cosa ti serve
  1. Steam Link Disassembly, Starting up: passo 1, immagine 1 di 2 Steam Link Disassembly, Starting up: passo 1, immagine 2 di 2
    • Start by unplugging your device
    • Power cord
    • Ethernet
    • HDMI
  2. Steam Link Disassembly, Removing the rubber bottom: passo 2, immagine 1 di 2 Steam Link Disassembly, Removing the rubber bottom: passo 2, immagine 2 di 2
    • Start by removing the rubber bottom using the Guitar Pick or the Jimmy
    • The first time, the adhesive may be difficult to remove
  3. Steam Link Disassembly, Removing the screws: passo 3, immagine 1 di 2 Steam Link Disassembly, Removing the screws: passo 3, immagine 2 di 2
    • Remove the screws using a Torxx 6 bit
  4. Steam Link Disassembly, Opening the lid: passo 4, immagine 1 di 2 Steam Link Disassembly, Opening the lid: passo 4, immagine 2 di 2
    • Open-up the bottom lid using guitar pics
    • The first time you open it, it might be difficult to open. Start by reaching the rounded, bottom-right corner
  5. Steam Link Disassembly, Main board inspection: passo 5, immagine 1 di 2 Steam Link Disassembly, Main board inspection: passo 5, immagine 2 di 2
    • Marvel ArmV7 CPU
    • Vivante GC1000 GPU
Conclusione
To reassemble your device, follow the steps in the opposite order
Altre 8 persone hanno completato questa guida.
4 Commenti
bonjour esque cette carte peu servire comme raspberry merci
thesmoking gta - Replica
Non, seule une image signée par Valve peut être lancée. Elle a un accès SSH comme indiqué sur la page du SDK cependant. Notez qu'elle n'est plus fabriquée depuis décembre, donc elle n'est plus vraiment disponible.
Jorys Paulin (Jorys_Paulin) -
Somewhat unworthy Teardown. Naming the CPU brand wrong and not giving any relevant information like schematics or ICs used. THIS is by far better: https://www.allaboutcircuits.com/news/te...
EDIT: Oh, it is a community post, sry. But more information would be nice. E.g. where is the massive heat sink? There are lots of parts missing.
Jan Seewald - Replica
Hello, this is my first (and only) teardown. I made it just for fun, really. I opened my Steam Link once and then decided to put it on the internet, because I found they weren’t that much photos of it around.
The heat sink is a large piece of aluminum, and now I realize I forgot to add it, my mistake.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 72
Tutti i Tempi: 4,763
