Salta al contenuto principale
Steam Deck Battery Replacement
Cosa ti serve
Panoramica Video
  1. Steam Deck Battery Replacement, Prepare your device: passo 1, immagine 1 di 3 Steam Deck Battery Replacement, Prepare your device: passo 1, immagine 2 di 3 Steam Deck Battery Replacement, Prepare your device: passo 1, immagine 3 di 3
    • Unplug any cables connected to your Steam Deck.
    • Turn on your Steam Deck and allow the battery to discharge below 5% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • Put your Steam Deck into battery storage mode within the BIOS. Read how to do that here.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • Pro tip: it can be helpful to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Battery Replacement, Remove the back cover screws: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $36.95
    Compra
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four 9.5 mm screws
    • Four 5.8 mm screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  3. Steam Deck Battery Replacement, Unclip the back cover: passo 3, immagine 1 di 2 Steam Deck Battery Replacement, Unclip the back cover: passo 3, immagine 2 di 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of one of the grips.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  4. Steam Deck Battery Replacement, Remove the back cover: passo 4, immagine 1 di 3 Steam Deck Battery Replacement, Remove the back cover: passo 4, immagine 2 di 3 Steam Deck Battery Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  5. Steam Deck Battery Replacement, Uncover the hidden shield screw: passo 5, immagine 1 di 2 Steam Deck Battery Replacement, Uncover the hidden shield screw: passo 5, immagine 2 di 2
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  6. Steam Deck Battery Replacement, Remove the shield screws: passo 6, immagine 1 di 2 Steam Deck Battery Replacement, Remove the shield screws: passo 6, immagine 2 di 2
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  7. Steam Deck Battery Replacement, Remove the shield: passo 7, immagine 1 di 3 Steam Deck Battery Replacement, Remove the shield: passo 7, immagine 2 di 3 Steam Deck Battery Replacement, Remove the shield: passo 7, immagine 3 di 3
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  8. Steam Deck Battery Replacement, Disconnect the battery: passo 8, immagine 1 di 3 Steam Deck Battery Replacement, Disconnect the battery: passo 8, immagine 2 di 3 Steam Deck Battery Replacement, Disconnect the battery: passo 8, immagine 3 di 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  9. Steam Deck Battery Replacement, Disconnect the audio cable: passo 9, immagine 1 di 2 Steam Deck Battery Replacement, Disconnect the audio cable: passo 9, immagine 2 di 2
    • Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
  10. Steam Deck Battery Replacement: passo 10, immagine 1 di 2 Steam Deck Battery Replacement: passo 10, immagine 2 di 2
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by its pull tab, not by the cable itself.
  11. Steam Deck Battery Replacement, Peel back the audio cable: passo 11, immagine 1 di 3 Steam Deck Battery Replacement, Peel back the audio cable: passo 11, immagine 2 di 3 Steam Deck Battery Replacement, Peel back the audio cable: passo 11, immagine 3 di 3
    • Carefully peel the audio cable off of the battery.
    • The audio cable is secured to the battery with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the audio cable using an iOpener or a hair dryer to soften the adhesive.
  12. Steam Deck Battery Replacement, Disconnect the button board cable: passo 12, immagine 1 di 3 Steam Deck Battery Replacement, Disconnect the button board cable: passo 12, immagine 2 di 3 Steam Deck Battery Replacement, Disconnect the button board cable: passo 12, immagine 3 di 3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  13. Steam Deck Battery Replacement, Peel back the button board cable: passo 13, immagine 1 di 3 Steam Deck Battery Replacement, Peel back the button board cable: passo 13, immagine 2 di 3 Steam Deck Battery Replacement, Peel back the button board cable: passo 13, immagine 3 di 3
    • Carefully peel the button board cable off of the battery.
    • The button board cable is secured to the battery with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the button board cable using an iOpener or a hair dryer to soften the adhesive.
    • You may want to tape the audio and button board cables out of the way as you remove the battery.
  14. Steam Deck Battery Replacement, Cut a plastic card in half: passo 14, immagine 1 di 3 Steam Deck Battery Replacement, Cut a plastic card in half: passo 14, immagine 2 di 3 Steam Deck Battery Replacement, Cut a plastic card in half: passo 14, immagine 3 di 3
    • In order to slice the battery adhesive through two small slits near the bottom of the Steam Deck's frame, two thin cards are needed.
    • Use a pair of scissors to cut a plastic card in half, longways.
    • Round over any sharp corners, as they could scrape or puncture the battery.
  15. Steam Deck Battery Replacement, Heat the battery adhesive: passo 15, immagine 1 di 3 Steam Deck Battery Replacement, Heat the battery adhesive: passo 15, immagine 2 di 3 Steam Deck Battery Replacement, Heat the battery adhesive: passo 15, immagine 3 di 3
    • The battery is strongly adhered to the Steam Deck. The adhesive loosens with constant, steady force, and it will require repeated heating and prying cycles.
    • Heating a charged battery is a fire hazard. Make sure you've completely discharged your battery before starting this step.
    • Don't reuse the battery after it's been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Use a heat gun to heat the adhesive underneath the battery for 1-2 minutes.
    • Alternatively, a hair dryer may also be used.
    • Try your best to not overheat the battery. Keep the heat gun or hair dryer ~2 inches above the battery and constantly moving at all times—don't keep it heating one place for too long.
    • Although high-concentration isopropyl alcohol (>90%) may be an effective method to loosen this adhesive, there's a high risk of excess leaking onto or into the display or other components through the cutouts on the battery tray.
  16. Steam Deck Battery Replacement, Begin to pry up the battery: passo 16, immagine 1 di 3 Steam Deck Battery Replacement, Begin to pry up the battery: passo 16, immagine 2 di 3 Steam Deck Battery Replacement, Begin to pry up the battery: passo 16, immagine 3 di 3
    • Insert an uncut plastic card between the top edge of the battery and the frame.
    • Insert a second plastic card between the right edge of the battery and the frame.
    • Don't use excessive force or pry at the battery with metal tools.
    • Try your best not to deform the battery during this process. Soft-shell lithium-polymer batteries can leak dangerous chemicals, catch fire, or even explode if damaged.
    • The battery most likely won't budge at this step, but these cards will be helpful as leverage as you continue.
  17. Steam Deck Battery Replacement, Reheat the battery adhesive: passo 17, immagine 1 di 1
    • You'll need to repeatedly reheat the adhesive to further soften it. The adhesive is tough and it may take a few tries to get a card started under the battery.
  18. Steam Deck Battery Replacement, Slice the battery adhesive: passo 18, immagine 1 di 2 Steam Deck Battery Replacement, Slice the battery adhesive: passo 18, immagine 2 di 2
    • Insert one of the cut plastic cards under the battery near its bottom right edge.
    • Push the card in to slice the battery adhesive, wiggling it side-to-side as you go.
    • If this is overly difficult, you may need more heat.
  19. Steam Deck Battery Replacement: passo 19, immagine 1 di 2 Steam Deck Battery Replacement: passo 19, immagine 2 di 2
    • Insert the second cut plastic card under the battery near its bottom left edge.
  20. Steam Deck Battery Replacement, Pry out the battery: passo 20, immagine 1 di 3 Steam Deck Battery Replacement, Pry out the battery: passo 20, immagine 2 di 3 Steam Deck Battery Replacement, Pry out the battery: passo 20, immagine 3 di 3
    • Insert a plastic card along the bottom edge of the battery to pry the battery away from the frame.
    • Lift the battery up, away from the Steam Deck to fully separate it from all adhesive.
    • Don't use excessive force—try your best not to deform the battery during this process.
    • If you're having trouble, repeat the heating and prying process around all edges until the battery becomes loose.
  21. Steam Deck Battery Replacement, Remove the battery: passo 21, immagine 1 di 1
    • Remove the battery.
    • To install a replacement battery:
    • Dampen a lint-free cloth with some isopropyl alcohol (>90%) and use it to remove any remaining adhesive from the battery well. Don't use too much—avoid dripping any through the cutouts in the frame.
    • Peel and discard one side of protective liners on the new adhesives and apply them to the new battery, using your old battery as a reference for where they should adhere.
    • Peel and discard the remaining side of adhesive liners. Lay the battery in place and press firmly.
    • Remember: Don't reconnect the battery connector until you've finished reassembly!
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Altre 25 persone hanno completato questa guida.
Carsten Frauenheim
Membro da: 03/10/20
109.406 Reputazione
338 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.058 Guide realizzate
9 Commenti
Is it safe to apply small amounts of >90% isopropyl alcohol under the battery to loosen the adhesive bond? Or would that drip into the screen or other components and potentially cause damage?
RikiGuitarist - Replica
Your mileage may vary. Isopropyl alcohol may be an effective method to loosen the adhesive, but you run the risk of excess leaking onto or into the display or other components, due to the cutouts on the battery tray. Your second sentence is spot-on, hence the recommendation to carefully use heat instead.
Carsten Frauenheim -
Why couldn’t they of used pull tabs for the adhesive so this process would not be so difficult and tedious. It would also be less risk of over heating the battery/steam deck or puncturing the battery. This is really the only design choice I can criticize of the steam deck. Pull tabs would of made this a repair the average person could achieve.
Joshua Marram - Replica
I feel like patience is everything in this scenario I mean. Just take your time and relax & it will all be ok ! When dealing with particular situations like this just take you're time simple as that I promise. Especially, since Ifixit.com has some of the best guides EVER!!
sgtkickazzttv -
It seems crazy to me that they made this process so difficult, surely battery is one of (if not THE) most common things that you'll need to eventually replace? I suppose they must have been limited by what they could achieve?
Marc Johnson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 172
Ultimi 7 Giorni: 1,021
Ultimi 30 Giorni: 4,072
Tutti i Tempi: 110,334
