Salta al contenuto principale
Starbucks Barista Steam Wand replacement or cleaning
Cosa ti serve
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: passo 1, immagine 1 di 1
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: passo 2, immagine 1 di 2 Starbucks Barista Steam Wand replacement or cleaning: passo 2, immagine 2 di 2
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
Conclusione
Altre 4 persone hanno completato questa guida.
David
Membro da: 01/28/11
739 Reputazione
3 Guide realizzate
Cal Poly, Team 4-42, Regan Winter 2011 Membro di Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Membri
5 Guide realizzate
Un commento
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 15,854
