Introduzione
The ready light is a simple LED that shows when the Barista has heated up to its needed temperature. This LED may burn out or its connectors may loosen.
Cosa ti serve
Locate the ready light.
Gently push the fixture against the Barista wall.
Pull the fixture straight up to release it.
Note: The fixture works as a spring.
Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
Disconnect the wire lead connectors.
Remove the ready light unit (fixture).
4 Commenti
Beee2smoove.
Youth and sports for
Ttuii addinsists
