Salta al contenuto principale
Starbucks Barista Ready Light Replacement
Cosa ti serve
  1. Starbucks Barista Ready Light Replacement, Ready Light: passo 1, immagine 1 di 2 Starbucks Barista Ready Light Replacement, Ready Light: passo 1, immagine 2 di 2
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: passo 2, immagine 1 di 3 Starbucks Barista Ready Light Replacement: passo 2, immagine 2 di 3 Starbucks Barista Ready Light Replacement: passo 2, immagine 3 di 3
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: passo 3, immagine 1 di 1
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
Conclusione
David
Membro da: 01/28/11
739 Reputazione
3 Guide realizzate
Cal Poly, Team 4-42, Regan Winter 2011 Membro di Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Membri
5 Guide realizzate
4 Commenti
Youth and sports for
Rich Ridout - Replica
Ttuii addinsists
Where can I get a new LED bulb?
Paula - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 6,097
