Salta al contenuto principale
Introduzione
The ready light is a simple LED that shows when the Barista has heated up to its needed temperature. This LED may burn out or its connectors may loosen.
Parti
Nessuna parte specificata.
  1. Unscrew the 6 screws from the back panel. Remove the back panel.
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Locate the ready light. Gently push the fixture against the Barista wall. Pull the fixture straight up to release it.
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Replace the old LED with a new LED.
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
Conclusione
David
Membro da: 28/01/2011
613 Reputazione
3 Guide realizzate
Cal Poly, Team 4-42, Regan Winter 2011 Membro di Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Membri
5 Guide realizzate
Beee2smoove.
Rich Ridout - Replica
Youth and sports for
Ttuii addinsists
Where can I get a new LED bulb?
Paula - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 5,242
