Salta al contenuto principale
Stanley ST-222A-120 Pressure Sensor Replacement
  1. Stanley ST-222A-120 Pressure Sensor Replacement, Pressure Sensor: passo 1, immagine 1 di 1
    • Unplug the heater for safety during your repair.
  2. Stanley ST-222A-120 Pressure Sensor Replacement: passo 2, immagine 1 di 3 Stanley ST-222A-120 Pressure Sensor Replacement: passo 2, immagine 2 di 3 Stanley ST-222A-120 Pressure Sensor Replacement: passo 2, immagine 3 di 3
    • With your hands gently remove the plastic covers on either side of the heater.
  3. Stanley ST-222A-120 Pressure Sensor Replacement: passo 3, immagine 1 di 2 Stanley ST-222A-120 Pressure Sensor Replacement: passo 3, immagine 2 di 2
    • Use your hands to pry apart the plastic halves of the heater to see the internals of the device.
  4. Stanley ST-222A-120 Pressure Sensor Replacement: passo 4, immagine 1 di 2 Stanley ST-222A-120 Pressure Sensor Replacement: passo 4, immagine 2 di 2
    • Locate small pressure sensor replacement and small pressure pin at the bottom of the device.
  5. Stanley ST-222A-120 Pressure Sensor Replacement: passo 5, immagine 1 di 2 Stanley ST-222A-120 Pressure Sensor Replacement: passo 5, immagine 2 di 2
    • Use your hands to help guide the pressure pin back into a position where the replacement plate can slide back onto it.
    • Needle nose pliers may be a good assistant in this situation.
  6. Stanley ST-222A-120 Pressure Sensor Replacement: passo 6, immagine 1 di 2 Stanley ST-222A-120 Pressure Sensor Replacement: passo 6, immagine 2 di 2
    • While the plastic is open hold the pin out with a finger.
    • Line up the pressure plate to the pressure pin.
  7. Stanley ST-222A-120 Pressure Sensor Replacement: passo 7, immagine 1 di 2 Stanley ST-222A-120 Pressure Sensor Replacement: passo 7, immagine 2 di 2
    • Gently put the pressure plate back onto the pressure pin.
  8. Stanley ST-222A-120 Pressure Sensor Replacement: passo 8, immagine 1 di 3 Stanley ST-222A-120 Pressure Sensor Replacement: passo 8, immagine 2 di 3 Stanley ST-222A-120 Pressure Sensor Replacement: passo 8, immagine 3 di 3
    • Carefully press the plastic back together.
    • Be conscious not to interrupt the placement of the newly repaired pressure plate.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 618
