Introduzione
This guide will show you how to replace the blade on a Stanley 10-079 Box Cutter.
Cosa ti serve
Here is the knife we will be replacing the blade on, its a Stanley 10-079 Box Cutter.
With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2.
insert the screw you first removed back into the hole in the center ensuring that you tighten it down not too tight to get undone without a power tool
You are all set and ready to use your brand new installed blade! Here are some replacement blades that I found on amazon. https://www.amazon.com/Stanley-11-921L-5...
