Salta al contenuto principale
Stagg Electro-Acoustic Guitar Strings Replacement
Cosa ti serve
  1. Stagg Electro-Acoustic Guitar Strings Replacement, Guitar Strings: passo 1, immagine 1 di 1
    • Place the string winder on the tuning key.
  2. Stagg Electro-Acoustic Guitar Strings Replacement: passo 2, immagine 1 di 1
    • Wind up the string winder counter-clockwise to loosen the strings.
  3. Stagg Electro-Acoustic Guitar Strings Replacement: passo 3, immagine 1 di 1
    • With the string clipper, clip the string under the neck of the guitar.
  4. Stagg Electro-Acoustic Guitar Strings Replacement: passo 4, immagine 1 di 1
    • Unwind the string from the machine head and remove it.
  5. Stagg Electro-Acoustic Guitar Strings Replacement: passo 5, immagine 1 di 1
    • With the string winder pop the string peg out of its hole.
  6. Stagg Electro-Acoustic Guitar Strings Replacement: passo 6, immagine 1 di 1
    • Place the colored circle end of the string in the peg hole.
  7. Stagg Electro-Acoustic Guitar Strings Replacement: passo 7, immagine 1 di 1
    • Put the peg in the hole with the string.
    • Pull the string while pushing the pin in.
  8. Stagg Electro-Acoustic Guitar Strings Replacement: passo 8, immagine 1 di 1
    • Precut the other side of the string by one and a half machine heads.
  9. Stagg Electro-Acoustic Guitar Strings Replacement: passo 9, immagine 1 di 1
    • Thread the string through the peg.
    • Wind the string clockwise from top to bottom with the string winder.
    • Do not overlap the string when winding it.
Conclusione
Repeat steps for each string.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 401
