Salta al contenuto principale
Squier Strat Guitar Pickups Replacement
Cosa ti serve
  1. Squier Strat Guitar Pickups Replacement, Pickups: passo 1, immagine 1 di 3 Squier Strat Guitar Pickups Replacement, Pickups: passo 1, immagine 2 di 3 Squier Strat Guitar Pickups Replacement, Pickups: passo 1, immagine 3 di 3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: passo 2, immagine 1 di 2 Squier Strat Guitar Pickups Replacement: passo 2, immagine 2 di 2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: passo 3, immagine 1 di 3 Squier Strat Guitar Pickups Replacement: passo 3, immagine 2 di 3 Squier Strat Guitar Pickups Replacement: passo 3, immagine 3 di 3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: passo 4, immagine 1 di 2 Squier Strat Guitar Pickups Replacement: passo 4, immagine 2 di 2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: passo 5, immagine 1 di 2 Squier Strat Guitar Pickups Replacement: passo 5, immagine 2 di 2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: passo 6, immagine 1 di 2 Squier Strat Guitar Pickups Replacement: passo 6, immagine 2 di 2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: passo 7, immagine 1 di 2 Squier Strat Guitar Pickups Replacement: passo 7, immagine 2 di 2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
Conclusione
Altre 4 persone hanno completato questa guida.
Ion
Membro da: 09/29/15
479 Reputazione
3 Guide realizzate
Cal Poly, Team 10-5, Green Fall 2015 Membro di Cal Poly, Team 10-5, Green Fall 2015
CPSU-GREEN-F15S10G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 72
Tutti i Tempi: 6,851
