Introduzione
This replacement is necessary if either the camera or display screen is faulty, since the two components cannot easily be separated. Even replacing the entire assembly is an extremely tedious task and requires quite a bit of meticulous soldering and de-soldering. It is not recommended for you to attempt this replacement unless you are highly skilled with a soldering iron. Take a look at the Device Troubleshooting Page before you begin to be sure that you have diagnosed the problem correctly.
Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
  • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
  • Pry open the device shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
Aggiungi Commento
Use your fingers to peel off the foam pad that covers the main circuit board.
  • Use your fingers to peel off the foam pad that covers the main circuit board.
  • Be careful not to tear the foam pad.
Aggiungi Commento
  • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and lift it out of its place.
  • Be careful not to put too much tension on the various wires.
Aggiungi Commento
  • Remove the one black 7.2 mm Phillips #0 screw from the plastic piece that holds down the microSD card reader wires.
  • Remove the two black 7.2 mm Phillips #0 screws that hold the microSD card reader in place.
  • You should now be able to lift the microSD card reader out of place.
Aggiungi Commento
  • Remove the two black Phillips #0 screws that hold down the camera & display screen assembly.
  • Pull the camera & display screen assembly up from its slot in the device.
Aggiungi Commento
  • Remove the four black 7.2 mm Phillips #0 screws that hold the screen assembly in place.
Where can I get the screen and what is the price?
th24toddh - Replica
  • Turn the device around to the other side and lift up the screen assembly.
  • Remove the four black 7.2 mm Phillips #00 screws that hold the lens & filter assembly in place.
  • Pull the lens & filter assembly away from the circuit board.
Aggiungi Commento
  • Using the soldering iron, de-solder the various wires from the front and back of the circuit board.
  • There are three pairs of wires on the front side, along with a set of 7 leads for the main circuit board connector.
  • On the back side, there is a set of 9 leads for the microSD card connector.
  • Check out This Guide for tips on soldering and de-soldering.
Aggiungi Commento
Conclusione
Andrew Gittens
Membro da: 22/09/2014
140 Reputazione
4 Guide realizzate
USF Tampa, Team 4-5, Brown Fall 2014 Membro di USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Membri
6 Guide realizzate
Boa tarde , na verdade não um comentario, meu spy ney esta com defeito( LCD display)gostaria quem pode me ajudar a me fornecer outro LCD com a placa, nome da loja, site, para exportar pro Brasil.
ribeiro928 - Replica
I’ve just bought one of these for £3, wondered if it’d be too risky to experiment with if I was to circuit bend it? I create visuals & if I added a couple of potentiometers to it, I’d be interested to see if I could get any wild effects from it. It’d be great if I could achieve it with this as I’d hopefully be able to save the videos too in order to put into my animations. Do you think I should avoid it, or has anyone attempted circuit bending one of these? Cheers
Neil Beil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 604
