Salta al contenuto principale
Spy Gear Video Walkie Talkies Camera Replacement
Cosa ti serve
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: passo 1, immagine 1 di 1
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: passo 2, immagine 1 di 1
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: passo 3, immagine 1 di 1
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: passo 4, immagine 1 di 1
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: passo 5, immagine 1 di 1
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: passo 7, immagine 1 di 2 Spy Gear Video Walkie Talkies Camera Replacement: passo 7, immagine 2 di 2
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: passo 8, immagine 1 di 1
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: passo 9, immagine 1 di 1
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: passo 10, immagine 1 di 1
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: passo 11, immagine 1 di 1
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: passo 12, immagine 1 di 1
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: passo 13, immagine 1 di 1
    • Discard faulty camera and mounting tray.
Conclusione
Altre 2 persone hanno completato questa guida.
James French
Membro da: 02/15/16
151 Reputazione
1 Guida realizzata
IUPUI, Team 7-7, Wilson Spring 2016 Membro di IUPUI, Team 7-7, Wilson Spring 2016
IUPUI-WILSON-S16S7G7
5 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 690
