Salta al contenuto principale
Sprout channel cubby outer trim Replacement
Cosa ti serve
  1. Sprout channel cubby outer trim Replacement, Dissasemble the device: passo 1, immagine 1 di 2 Sprout channel cubby outer trim Replacement, Dissasemble the device: passo 1, immagine 2 di 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout channel cubby outer trim Replacement, outer trim: passo 2, immagine 1 di 2 Sprout channel cubby outer trim Replacement, outer trim: passo 2, immagine 2 di 2
    • There are 19 tabs that need to be pushed out of the inner trim. The metal spudger works great here.
    • Do not push too hard on the tabs or they will break.
Conclusione
USF Tampa, Team 14-101, Meier Fall 2015 Membro di USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 446
