Salta al contenuto principale
Sprout Channel Cubby Speaker Replacement
Cosa ti serve
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: passo 1, immagine 1 di 2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: passo 1, immagine 2 di 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Speaker Replacement, Speaker: passo 2, immagine 1 di 2 Sprout Channel Cubby Speaker Replacement, Speaker: passo 2, immagine 2 di 2
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
  3. Sprout Channel Cubby Speaker Replacement: passo 3, immagine 1 di 2 Sprout Channel Cubby Speaker Replacement: passo 3, immagine 2 di 2
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
Conclusione
USF Tampa, Team 14-101, Meier Fall 2015 Membro di USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Membri
12 Guide realizzate
2 Commenti
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Replica
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,042
