Salta al contenuto principale
Sprint Sanyo RL-4920 Vibrator Motor Replacement
Cosa ti serve
  1. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Back of Phone: passo 1, immagine 1 di 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: passo 2, immagine 1 di 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: passo 2, immagine 2 di 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: passo 3, immagine 1 di 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: passo 3, immagine 2 di 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: passo 4, immagine 1 di 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: passo 5, immagine 1 di 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Vibrator Motor Replacement, The Front Case: passo 6, immagine 1 di 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: passo 7, immagine 1 di 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: passo 7, immagine 2 di 2
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 8, immagine 1 di 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 8, immagine 2 di 2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 9, immagine 1 di 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 9, immagine 2 di 2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 10, immagine 1 di 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 10, immagine 2 di 2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
  11. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Vibrator Motor: passo 11, immagine 1 di 1
    • Use a Phillips-head screw bit to remove the screw under the yellow film
  12. Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 12, immagine 1 di 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 12, immagine 2 di 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 12, immagine 3 di 3
    • Use the spudger tool to pry the latches ways from the circuit board
    • Detach the metal casing from the circuit board
  13. Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 13, immagine 1 di 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 13, immagine 2 di 2
    • Remove wires attaching vibrator motor to circuit board gently so as not to damage them
  14. Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 14, immagine 1 di 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 14, immagine 2 di 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 14, immagine 3 di 3
    • Once the metal casing is removed from the circuit board take it and locate the vibrator motor on the top side of the casing
    • Use the spudger tool to gently pry the vibrator motor out of its protective shell
  15. Sprint Sanyo RL-4920 Vibrator Motor Replacement: passo 15, immagine 1 di 1
    • With the vibrator motor completely removed, you can now replace it with a new one
Conclusione
Austin Shores
Membro da: 10/18/13
301 Reputazione
3 Guide realizzate
Clemson, Team 13-5, Benson Fall 2013 Membro di Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 310
