Salta al contenuto principale
Sprint Sanyo RL-4920 Speaker Replacement
Cosa ti serve
  1. Sprint Sanyo RL-4920 Speaker Replacement, Back of Phone: passo 1, immagine 1 di 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: passo 2, immagine 1 di 2 Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: passo 2, immagine 2 di 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 3, immagine 1 di 2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 3, immagine 2 di 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: passo 4, immagine 1 di 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: passo 5, immagine 1 di 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Speaker Replacement, The Front Case: passo 6, immagine 1 di 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 7, immagine 1 di 2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 7, immagine 2 di 2
    • Locate the three screws securing the speaker.
    • Use a Phillips-head screw bit to unscrew the screws
  8. Sprint Sanyo RL-4920 Speaker Replacement, Replace Speaker: passo 8, immagine 1 di 1
    • Remove the speaker.
    • Replace with new speaker.
    • Secure new speaker with screws and reassemble phone.
Conclusione
Austin Shores
Membro da: 10/18/13
301 Reputazione
3 Guide realizzate
Clemson, Team 13-5, Benson Fall 2013 Membro di Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 171
