Introduzione
Step by step instructional guide to replacing Spin Master Hatchimal Draggle speaker. Before getting started, fur and wing removal is required.
  1. lay the Hatchimal on its side.
    • lay the Hatchimal on its side.
  2. Using the plastic opening tool, push in on the purple clip.
    • Using the plastic opening tool, push in on the purple clip.
  3. Pull the wing off of the hatchimal.
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Cut the fur retaining zip-tie with a pair of scissors. Cut the fur retaining zip-tie with a pair of scissors.
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Lift the fur up until it can't go further. Lift the fur up until it can't go further.
    • Lift the fur up until it can't go further.
  6. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  7. Use the spudger tool to push up on the black clip to free it. Pull the clip out. Pull the clip out.
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  8. Lift fur up to reveal the next set of clips. Insert a spudger to push up on the black clip to free it. Pull out the clip.
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  9. Lift the fur up and over the Hatchimals Head. Remove the six 12mm Phillips #00 screws from then body.
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  10. Pull the casing apart. Remove the yellow speaker cable.
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  11. Remove the three 7mm Phillips #00 screws from the head. Remove the wheel base and the circuit board carefully not to damage the spring. Remove the wheel base and the circuit board carefully not to damage the spring.
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  12. Push the six black fur clips out using the spudger. Remove the fur completely.
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
  13. Gently pull the yellow speaker cord from circuit board. There will be little resistance.
    • Gently pull the yellow speaker cord from circuit board. There will be little resistance.
  14. Remove the two 7mm Philips #00 screws from the head. Remove the two 7mm Philips #00 screws from the head.
    • Remove the two 7mm Philips #00 screws from the head.
  15. Pull the speaker cover off. Remove the speaker.
    • Pull the speaker cover off.
    • Remove the speaker.
Conclusione
Hector Lopez
Membro da: 14/02/2018
245 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G5, Nance Spring 2018 Membro di USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
3 Membri
5 Guide realizzate
Where can I get a new speaker?
Jeff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 548
