Salta al contenuto principale
Spin Master Hatchimal Draggle Fur Replacement
Cosa ti serve
  1. Spin Master Hatchimal Draggle Fur Replacement, Plastic Wing Replacement: passo 1, immagine 1 di 1
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Fur Replacement: passo 2, immagine 1 di 1
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Fur Replacement: passo 3, immagine 1 di 1
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: passo 4, immagine 1 di 2 Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: passo 4, immagine 2 di 2
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Fur Replacement: passo 5, immagine 1 di 2 Spin Master Hatchimal Draggle Fur Replacement: passo 5, immagine 2 di 2
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Fur Replacement: passo 6, immagine 1 di 3 Spin Master Hatchimal Draggle Fur Replacement: passo 6, immagine 2 di 3 Spin Master Hatchimal Draggle Fur Replacement: passo 6, immagine 3 di 3
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Fur Replacement: passo 7, immagine 1 di 3 Spin Master Hatchimal Draggle Fur Replacement: passo 7, immagine 2 di 3 Spin Master Hatchimal Draggle Fur Replacement: passo 7, immagine 3 di 3
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Fur Replacement: passo 8, immagine 1 di 2 Spin Master Hatchimal Draggle Fur Replacement: passo 8, immagine 2 di 2
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Fur Replacement: passo 9, immagine 1 di 2 Spin Master Hatchimal Draggle Fur Replacement: passo 9, immagine 2 di 2
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Fur Replacement: passo 10, immagine 1 di 3 Spin Master Hatchimal Draggle Fur Replacement: passo 10, immagine 2 di 3 Spin Master Hatchimal Draggle Fur Replacement: passo 10, immagine 3 di 3
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Fur Replacement: passo 11, immagine 1 di 2 Spin Master Hatchimal Draggle Fur Replacement: passo 11, immagine 2 di 2
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
Conclusione
USF Tampa, Team S1-G5, Nance Spring 2018 Membro di USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 716
