Salta al contenuto principale
Spin Master Boxer Remote Trigger Buttons Replacement
Cosa ti serve
  1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: passo 1, immagine 1 di 1
    • Lay the remote flat on your work space, with joysticks facing you.
  2. Spin Master Boxer Remote Trigger Buttons Replacement: passo 2, immagine 1 di 1
    • Remove both joysticks by gripping under circular knob and gently pulling towards you.
    • The joysticks should detach without much effort.
  3. Spin Master Boxer Remote Trigger Buttons Replacement: passo 3, immagine 1 di 1
    • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
    • Remove the batteries from the remote and set it to side.
    • Use the same screwdriver to remove all four 4mm screws on back panel.
  4. Spin Master Boxer Remote Trigger Buttons Replacement: passo 4, immagine 1 di 2 Spin Master Boxer Remote Trigger Buttons Replacement: passo 4, immagine 2 di 2
    • Insert the Jimmy in between the top panel and the bottom panel.
    • Gently use the Jimmy to separate both plastic panels from each other.
    • Pull the panels apart and set bottom piece on workbench.
  5. Spin Master Boxer Remote Trigger Buttons Replacement: passo 5, immagine 1 di 2 Spin Master Boxer Remote Trigger Buttons Replacement: passo 5, immagine 2 di 2
    • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
    • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
Conclusione
Lauren Roide
Membro da: 04/16/19
739 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G1, Maness Spring 2019 Membro di Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,064
