Salta al contenuto principale
Sphero Ollie Motor Replacement
Cosa ti serve
  1. Sphero Ollie Motor Replacement, Tires and Hubcaps: passo 1, immagine 1 di 1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Motor Replacement: passo 2, immagine 1 di 2 Sphero Ollie Motor Replacement: passo 2, immagine 2 di 2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Motor Replacement, Motherboard: passo 3, immagine 1 di 1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Motor Replacement: passo 4, immagine 1 di 2 Sphero Ollie Motor Replacement: passo 4, immagine 2 di 2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Motor Replacement: passo 5, immagine 1 di 2 Sphero Ollie Motor Replacement: passo 5, immagine 2 di 2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
  6. Sphero Ollie Motor Replacement, Motor: passo 6, immagine 1 di 3 Sphero Ollie Motor Replacement, Motor: passo 6, immagine 2 di 3 Sphero Ollie Motor Replacement, Motor: passo 6, immagine 3 di 3
    • After you have removed the motherboard, use a JIS #1 screwdriver to remove the four 10mm screws holding in the cog shields.
    • Next, you want to pull apart the clips (two on each side) holding the top piece of the shield to the frame.
    • Then, once you have freed the cogs, you can lift the cog and remove it from the frame.
    • To completely remove the cog shield out of the way, carefully remove the black pin connectors from the slot in the shield.
    • Then, gently remove the wheels from the case
  7. Sphero Ollie Motor Replacement: passo 7, immagine 1 di 1
    • Once you have removed the cog out of the way, you can then pinch the clip on both sides to remove the cover protecting the battery
  8. Sphero Ollie Motor Replacement: passo 8, immagine 1 di 3 Sphero Ollie Motor Replacement: passo 8, immagine 2 di 3 Sphero Ollie Motor Replacement: passo 8, immagine 3 di 3
    • After you have removed the battery cover, flip the device around to view the motors
    • Loosen and use a JIS #1 screwdriver to remove the two 10mm Screws holding the clear case of the motors
    • Next, gently push the clip (on both sides) with a screwdriver to release the clear case
    • To remove the motors, simply pull on it with slight force
Conclusione
Kakkada Tho
Membro da: 10/18/17
432 Reputazione
2 Guide realizzate
UW Tacoma, Team S1-G3, Rose Fall 2017 Membro di UW Tacoma, Team S1-G3, Rose Fall 2017
UWT-ROSE-F17S1G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 44
Tutti i Tempi: 1,306
