Introduzione
This guide will illustrate how to easily replace the motherboard on the Sphero Ollie with only your hands, Plastic Opening Tool and a Phillips-Head Screwdriver.
Cosa ti serve
Firmly grasp Ollie in one hand.
Remove the blue rubber tire in a peeling motion with your opposite hand.
Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
Remove the plastic tire frame from the device
Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
Loosen and remove the 10mm screws holding the antenna to the case.
Gently remove mother board from the case with an upward motion.
Altre 2 persone hanno completato questa guida.
