Salta al contenuto principale
Sphero Ollie Motherboard Replacement
Cosa ti serve
  1. Sphero Ollie Motherboard Replacement, Tires and Hubcaps: passo 1, immagine 1 di 1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Motherboard Replacement: passo 2, immagine 1 di 2 Sphero Ollie Motherboard Replacement: passo 2, immagine 2 di 2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Motherboard Replacement: passo 4, immagine 1 di 2 Sphero Ollie Motherboard Replacement: passo 4, immagine 2 di 2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Motherboard Replacement: passo 5, immagine 1 di 2 Sphero Ollie Motherboard Replacement: passo 5, immagine 2 di 2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
Conclusione
Altre 2 persone hanno completato questa guida.
UW Tacoma, Team S1-G3, Rose Fall 2017 Membro di UW Tacoma, Team S1-G3, Rose Fall 2017
UWT-ROSE-F17S1G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 721
