Salta al contenuto principale
Speaker Bose SoundDock Motherboard Replacement
Cosa ti serve
  1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: passo 1, immagine 1 di 2 Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: passo 1, immagine 2 di 2
    • Remove the battery by pressing your finger down on the center button and twisting it counter-clockwise.
    • Remove battery and set it aside.
  2. Speaker Bose SoundDock Motherboard Replacement: passo 2, immagine 1 di 1
    • Use a plastic scraper to remove the rubber gasket from the bottom of speaker system and set it aside.
  3. Speaker Bose SoundDock Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a standard sized Phillips Screwdriver to remove the four screws on the bottom of the speaker system.
  4. Speaker Bose SoundDock Motherboard Replacement: passo 4, immagine 1 di 1
    • Using a smaller flat head screw driver, unscrew the semi-circle plate from bottom to expose the motherboard.
    • Once the components are unscrewed, the plastic dock frame may fall out.
  5. Speaker Bose SoundDock Motherboard Replacement: passo 5, immagine 1 di 1
    • Gently pull both ribbon cables out of the motherboard.
  6. Speaker Bose SoundDock Motherboard Replacement: passo 6, immagine 1 di 1
    • Replace it with new motherboard by plugging in the thinner wire into the small slot, and the larger wire into the wider slot.
    • Reverse steps 1 through 4 to reassemble dock.
Conclusione
Dalton Alexandre
Membro da: 02/24/15
123 Reputazione
1 Guida realizzata
Cal Poly, Team 24-5, Green Winter 2015 Membro di Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Membri
4 Guide realizzate
1 Guide Comment
Where can you buy the motherboard?
Steffen Jensen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,345
