Salta al contenuto principale
SoundBot SB571 Battery Replacement
Cosa ti serve
  1. SoundBot SB571 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the outside cover.
  2. SoundBot SB571 Battery Replacement: passo 2, immagine 1 di 1
    • Reorient the speaker so the black panel is facing up.
    • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
    • Now remove the plate.
  3. SoundBot SB571 Battery Replacement: passo 3, immagine 1 di 1
    • Reorient the speaker so the bottom is facing up.
    • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
    • Now open the plate.
  4. SoundBot SB571 Battery Replacement: passo 4, immagine 1 di 2 SoundBot SB571 Battery Replacement: passo 4, immagine 2 di 2
    • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
  5. SoundBot SB571 Battery Replacement: passo 5, immagine 1 di 2 SoundBot SB571 Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery wires from the circuit board.
  6. SoundBot SB571 Battery Replacement: passo 6, immagine 1 di 3 SoundBot SB571 Battery Replacement: passo 6, immagine 2 di 3 SoundBot SB571 Battery Replacement: passo 6, immagine 3 di 3
    • Reorient the speaker so the back side is facing up.
    • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
    • Loop the battery wires through the opening in the back plate.
    • The battery and it's connective wires have been completely removed from the speaker.
Conclusione
Altre 10 persone hanno completato questa guida.
Yana
Membro da: 02/09/16
618 Reputazione
2 Guide realizzate
USF Tampa, Team 2-50, Cagle Spring 2016 Membro di USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 Membri
2 Guide realizzate
8 Commenti
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - Replica
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - Replica
They don't sell batteries!!
international.loop - Replica
It says above that battery not for sale.
A simple online search and you will find the battery.
Mark Friend - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 8,677
