Introduzione
Replacing the battery requires opening up the speaker and unscrewing the bottom and upper part of the speaker. You will need a Phillips screw driver, blue plastic opening tool and a new battery.
Cosa ti serve
Place the speaker on a flat surface.
Take your blue plastic opening tool and remove the outside cover.
Reorient the speaker so the back side is facing up.
Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
Loop the battery wires through the opening in the back plate.
The battery and it's connective wires have been completely removed from the speaker.
Altre 12 persone hanno completato questa guida.
9Commenti sulla guida
Please provide the source to buy the replacement battery
They don't sell batteries!!
It says above that battery not for sale.
A simple online search and you will find the battery.
