Introduzione
Questa guida ti aiuterà a sostituire gli speaker se stai avendo dei problemi con l'audio.
Ricambi
Appoggia il GamePad a faccia in giù e svita le due viti da 4,7 mm con un cacciavite a croce Phillips #00.
Con le dita, premi sul connettore della batteria e tiralo all'indietro.
Rimuovi la batteria dal suo alloggio.
Svita le 10 viti da 9 mm attorno alla copertura esterna con un cacciavite Tri-Wing Y1.
Solleva la copertura posteriore.
Scollega il connettore del motore della vibrazione dalla scheda madre con le dita.
I agree. A circle over the plug would have been better as the picture looks like you just pull on the wires lol.
Chris -
Thanks for the comment. I did get a set of tweezers and the negative cable broke anyway. They really could have done a better job at using a different connector for that.
Why in the world is this thing so tightly connected?
Thanks for the comment. I did get a set of tweezers to try to pull it out but still ended up breaking the negative cable. They really could have used a better set of cables and connectors for this.
Con le dita, scollega il cavo dello speaker sinistro dalla scheda madre.
Speakers are connected with solder so removing them is not possible without requiring soldering later on. I left them both connected and instead of removing the motherboard completely I just "hinged" it carefully down to facilitate the work following step 18.
Thank you for offering this info because I spent 20 minutes between scratching my head and searching for any alternatives to just the image above, which had a wire nut/housing (and mine certainly did not). As I began to have an anxiety attack (
Mine also did not have connectors for the speaker. But like mentioned above, I was able to do repair WITHOUT the need to unsolder the speaker wires. Thanks!
Scollega il cavo dello speaker destro dalla scheda madre con delle pinzette.
Note that on some units (presumably later ones), the speakers are soldered onto the motherboard.
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Altre 4 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
tried to unscrew the 10 Tri-Wing size Y1 screw with my iFixIt toolkit
unfortunately the tool is too “fat” and short, it cannot reach 4 screws on the corners of the gamepad.
having the iFixIt toolkit and needing to purchase an additional slim screwdriver it’s a shame…
Antonello Iannone - Replica
