Salta al contenuto principale
Introduzione
Segui questa guida per sostituire una scheda madre difettosa.
Non dimenticarti di seguire la nostra guida per l'applicazione della pasta termica dopo aver rimosso il dissipatore.
    • Rimuovi le 10 viti seguenti che fissano il coperchio inferiore al case superiore:
    • Due viti Pentalobe P5 da 2,3 mm
    • Otto viti Pentalobe P5 da 3,0 mm
    • Nel corso di tutta la riparazione, tieni traccia di ogni vite e assicurati che ritorni nel suo posto originario per evitare danni al tuo dispositivo.
    For all the screws you use the P5 pentalobe screwdriver?
    Carlos - Replica
    Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
    Fredrik -
    I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
    marketing - Replica
    I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
    On a side note, only use quality tools, the cheap ones will break or strip the screws.
    Dustin Steward - Replica
    Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
    All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
    All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
    When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
    doubleclutch - Replica
    This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
    Evan Shulman -
    A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
    Note that this is a useful technique when installing ANY threaded fastener.
    Hi peeps,
    I have a wifi problem on this MBP 13” early 2015 and was pleasently surprised to find your guide to changing the airport card.
    However upon closer inspection it seems that on my MBP (purchased new or so I thought) the 3 antennae seem so have been soldered together at the point where they are clamped to the chassis. I have photos but cannot post here. Can anyone conform that where the 3 antennae wires are held to the chssis by the 2 scew metal support (just before disappearing into the screen hinge), the support is not meant to short the 3 wires together. This makes no sense for 3 seperate antennae wires.
    Any advice /close up photos is welcome here.
    dom
    colonel mustard - Replica
    Tip: Use post-it notes to keep track of screws
    1. Pack of post it notes
    2. Stick screws to the sticky part of the post it note
    3. Write on the post it note which step and what kind of screw it is
    ibash - Replica
    Hi, in order to drain the battery I am running:
    yes > /dev/null
    in 4 terminals, so the CPU maxes out at almost 99%.
    I hope this speeds up the battery draining process.
    And the backlight is at maximum brightness :-)
    You can see the cpu load in Activity Monitor.
    Its draining at 20% per 15 minutes.
    Any concerns about draining the battery in this way?
    Andre van der Ham - Replica
    Something I’ve been curious about, is it possible to upgrade a late 2013 Retina model MacBook Pro, with the improved 16gb ram and i7 processor logic board from the 2015 retina model? I’d be interested to try but not ready to shell out the $500+ to be the first lol
    Chat Dawgie - Replica
    Without rehashing what others have said, I would highly recommend reading through the steps *and* the comments for each before tackling your replacement for tips. Highlights for me were: only disconnecting what actually needed to be disconnected, rotating the spudger to release the track pad cable, a hair dryer worked perfectly fine, and the pencil outline of the battery before you remove. You got this!
    N DesRochers - Replica
    Installation of replacement AirPort card was easier than I had expected thanks to this guide. Thank you.
    chaslaw - Replica
    I use replaced SSD and it was super easy and working great. I can finally upgrade Mac OS with plenty of room to spare and no more low memory alerts. Well worth investment and didn’t have to buy new laptop
    Pete James - Replica
    It's interesting that this tutorial is rated Moderate even though you need to remove the battery. The battery removal tutorial which is basically the same but with fewer steps is rated Difficult.
    Marv Ruona - Replica
    when i pulled the screws out i arranged them in the same way they were in. the top 2 middle screws appeared to be shorter than the rest. in order to keep them in place i got a square of packing tape sticky side up, taped both sides down with 2 other pieces of tape. and then put the screws head down in the order i pulled them.
    Jason Wade - Replica
  1. Infila le tue dita tra il case superiore e quello inferiore.
    • Infila le tue dita tra il case superiore e quello inferiore.
    • Con delicatezza, tira il coperchio inferiore per staccarlo da quello superiore.
    This takes a bit more effort than you might expect. Put your fingers where shown and lift about 3inches. With enough upwards pressure the plastic holders will “pop free” and the bottom will come off easily.
    hamiltont - Replica
    To reattach bottom case I found it helpful to line fingers up with clips under case should snap easily
    Peter Stoll - Replica
    If your old battery has swollen, the lower case may “pop” open. Don’t lose your screws!
    Maxine Loveman - Replica
  2. Il case inferiore è collegato a quello superiore con due clip di plastica in posizione centrale. Durante il rimontaggio, spingi con delicatezza il centro del case inferiore per riattaccare le due clip in plastica.
    • Il case inferiore è collegato a quello superiore con due clip di plastica in posizione centrale.
    • Durante il rimontaggio, spingi con delicatezza il centro del case inferiore per riattaccare le due clip in plastica.
    This wording I found quite confusing. They just mean when putting the lid back on that you just removed in the previous step, push here.
    Mmm ttt - Replica
    I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
    Evan Shulman - Replica
    If you’re doing an iFixIt battery replacement, the replacement battery has two rubber nubs which are right where the clips are that receive these studs. Folks have been saying it’s hard to get the studs to clip back in after replacement, and I had the same issue. I trimmed the top of these rubber nubs, which are a bit bigger than those on the original battery, with some side cutters. That made the fit much better.
    Rob Gorbet - Replica
  3. Se necessario, rimuovere la copertura in plastica attaccata alla scheda contatti della batteria.
    • Se necessario, rimuovere la copertura in plastica attaccata alla scheda contatti della batteria.
    A plastic foam cover also covers plug and socket and the whole battery. It is easy to remove it from the right side to the trackpad wire that the battery plug is free like shown in the picture. I kept it to use it again later.
    Daniel Brehm - Replica
    I have done tons of these battery replacements.
    You don’t need to do anything on the list after you disconnect the battery, apart from carefully moving the speakers out of the way, and then prise up the battery modules. I just very carefully, and with little even motions, use a large slot screwdriver. Being careful to keep it flat, to not puncture the battery.
    Easy peasy. I have never had an issue after dozens of the tasks…
    davelarose - Replica
    Dear Sir,
    as you seem to be very much experienced with battery replacements you might perhaps give me a hint why after having removed the battery pack successfilly, the keyboard doesn't work anymore after booting the system. The Touchpad works, the keyboard backlight works but typing does not function at all.
    I only disconnected the battery connector and touched nothing else. I am quite desperate …
    Gerd Uyan -
    I agree with Dave la Rose, provided you use heat rather than solvent to remove the old battery (or possibly floss, haven’t done that). Please see my comment further down this thread on how to use an iOpener for correctly heating the glue joint
    I. Margaronis - Replica
  4. Usa l'estremità piatta di uno spudger per sollevare il connettore della batteria in verticale dal suo zoccolino sulla scheda logica. Accertati di sollevare solo il connettore e non lo zoccolino, per evitare il rischio di danni permanenti alla scheda logica.
    • Usa l'estremità piatta di uno spudger per sollevare il connettore della batteria in verticale dal suo zoccolino sulla scheda logica.
    • Accertati di sollevare solo il connettore e non lo zoccolino, per evitare il rischio di danni permanenti alla scheda logica.
    I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
    jramsey21 - Replica
    Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
    andrehedegaard -
    When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
    Ethan Tarquin - Replica
    +1
    I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
    Jonas Ehrs -
    Removing the battery connector took a bit of finagling. It wasn’t as easy as one would think. Be very careful when doing this as they warn to not damage it. Otherwise great instructions!!!!
    Peppon - Replica
    Lift from the long, flat side, not the shorter side. In this picture, you should lift from the NORTH part of the connector, not the WEST side like they are doing. This is because you can spread the pressure from lifting the connector across more area, as compared to the side. I accidentally broke off part of my battery connector lifting it up the way shown, but was able to do it the way I described without problem. Make sure to lift from the wide part so you don’t have my same trouble!
    Jaden Salama - Replica
    The connector is no more than 1mm thick… the socket is 3-to-4mm deep so make sure you’re trying to remove the connector itself, and not pulling at the socket.
    Richie Egg - Replica
    Thank you Richie I was trying to lift the socket.
    be careful the little square block is actually made of 2 parts and you only have to lift the upper part as Richie said
    ilyes - Replica
    You can do it from the side like the picture, but i would recommend twisting almost like a screw driver once you have leverage under the overhanging part of the left side like in the picture. Twist the tool so that it starts to put pressure on the top, until you’ll hear it click out. You can be somewhat forceful but it shouldn’t require a lot of strength. Guiding the tool with one hand and twisting with the other is a good way to attempt this.
    Colin Nowers - Replica
    After I put the battery back I found out at this step that the new battery connector was off by 2 mm (because I installed my battery slightly off). Since the connector is rigid, I removed it’s plastic cover (just like we all did in Step 4) to free the cable, which allowed me to bent it enough to properly plug the connector.
    Marc - Replica
  5. Piega il connettore della batteria in modo che non interferisca, per prevenire un contatto accidentale con lo zoccolino durante la riparazione.
    • Piega il connettore della batteria in modo che non interferisca, per prevenire un contatto accidentale con lo zoccolino durante la riparazione.
    If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
    sebasgaes - Replica
    I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
    LaymanLab - Replica
  6. Rimuovi attentamente il supportoammortizzatore  in gomma della ventola dal bordo del dissipatore. Il supporto della ventola abbraccia il dissipatore e si infila negli slot presenti nella presa d'aria. Durante il rimontaggio assicurati di incastrare le sue alette nelle rientranze nel condotto della ventola. Il supporto della ventola abbraccia il dissipatore e si infila negli slot presenti nella presa d'aria. Durante il rimontaggio assicurati di incastrare le sue alette nelle rientranze nel condotto della ventola.
    • Rimuovi attentamente il supportoammortizzatore in gomma della ventola dal bordo del dissipatore.
    • Il supporto della ventola abbraccia il dissipatore e si infila negli slot presenti nella presa d'aria. Durante il rimontaggio assicurati di incastrare le sue alette nelle rientranze nel condotto della ventola.
    For reassembly, I found it easier to loosen the lone top left 2.4 mm Phillips #000 before putting the fan bumper back in.
    Boston Hampton - Replica
    I don’t think you need to remove the heat sink for this
    Mike C - Replica
  7. Usa la parte piatta di uno spudger per rimuovere gli adesivi in schiuma dalle viti del dissipatore. Usa la parte piatta di uno spudger per rimuovere gli adesivi in schiuma dalle viti del dissipatore.
    • Usa la parte piatta di uno spudger per rimuovere gli adesivi in schiuma dalle viti del dissipatore.
    How should I reapply those little foam stickers? I guess not with normal glue.
    bboy.sidekick - Replica
    I found that the adhesive came up with the foam except for one screw. The adhesive just stuck to the head of the screw so I left it intact as much as possible and just pressed the foam back on. It doesn’t take much to keep them in place.
    Ryan Sooley - Replica
    If the new Logc Board coms with a heat sink attached, It is not necessary to remove the old one. Just unscrew the screw in the left corner of the heat sink and screws of the fan as well.
    Viktor Simeonov - Replica
    Est-ce grave si on les a perdu ?
    Louis BONIN - Replica
    The tiny rubber foam stickers help to keep the distance between the aluminium back cover and the black heat sink. I would recommend to install them or look for something similar.
    dvelasquez - Replica
  8. Svita le seguenti viti che fissano il dissipatore alla scheda madre:
    • Svita le seguenti viti che fissano il dissipatore alla scheda madre:
    • Quattro viti Torx T5 da 2,6 mm
    • Una vite a croce Phillips #000 da 2,4 mm
    The cross-head screwdriver bit was not the #000, the #00 was the right one.
    Benjamin Hug - Replica
    For my mac, the cross-head screwdriver bit was not the #000, was the T5
    maestrorafael - Replica
  9. Rimuovi il dissipatore dal portatile. Quando rimonti il tuo portatile, segui la nostra guida per l'applicazione della pasta termica per riapplicarla su processore e dissipatore.
    I bought all the tools necessary from iFixit except for the cleaning solutions for this step. You can just use isopropyl alcohol with a microfiber cloth to clean the thermal paste off before re-applying a new coat.
    Totally forgot the thermal paste when I bought the replacement fan. Then I needed to wait 2 days for some arctic silver 5 to arrive. All worked well in the end. I combined it with the batterie replacement, worked well together.
    Daniel - Replica
  10. Usa la punta di uno spudger per spingere su entrambi i lati del connettore del cavo della fotocamera iSight e sfilare il connettore man mano dalla sua presa sulla scheda madre. Usa la punta di uno spudger per spingere su entrambi i lati del connettore del cavo della fotocamera iSight e sfilare il connettore man mano dalla sua presa sulla scheda madre.
    • Usa la punta di uno spudger per spingere su entrambi i lati del connettore del cavo della fotocamera iSight e sfilare il connettore man mano dalla sua presa sulla scheda madre.
    I found this to be the most difficult step. There is a need to get positioned so that you have the leverage to push hard enough at exactly the point shown in the photo without risking slipping and perhaps damaging the CPU nearby
    Tony M - Replica
    Very helpful tip from Tony.
    Thomas Sturgill - Replica
    I used two tools simultaneously. A spudger and a pic like spudger to walk it out.
    lucas - Replica
    Man muss den Stecker aus der Steckverbindung herausschieben, und nicht darauf drücken . In der englischsprachigen Anleitung steht auch push und nicht etwa press…
    Holger - Replica
    There are 2 black tabs either side - force them towards the back of the back of computer. It seemed to pop out super easily just doing it gently.
    Josh - Replica
    This step is very difficult. With care it could be omitted. After detach the cable from the glue on the back cover of fan, there is enough clearance to take the fan assembly out with a little pivoting, just be careful and don’t put too much stress on the table where it make a 90 downward turn to the connector. Reinstalling is just reverse and doable as well.
    Xiaokun Xu - Replica
    After readying all, trying Josh’s tip with no joy, I found that two nice sized fingernails made this easy x 2! Just push on each little indent simultaneously.
    Ross Elkins - Replica
    Thanks Ross! This was my 2nd time every opening a laptop and using two finger nails to push on the little indents worked amazing!
    Carolyn Wang - Replica
    I pulled the cable directly and it got off easily.
    When assembling it,just used two fingernail on two sides of the plug and pushing it back。
    After all these,checked iSight working well。
    Junjie2021 - Replica
  11. Rimuovi il cavo della fotocamera iSight dalla ventola e piegalo da parte in modo che non sia di intralcio. Rimuovi il cavo della fotocamera iSight dalla ventola e piegalo da parte in modo che non sia di intralcio.
    • Rimuovi il cavo della fotocamera iSight dalla ventola e piegalo da parte in modo che non sia di intralcio.
  12. Usa la punta di uno spudger per ribaltare l'aletta di bloccaggio del connettore ZIF della ventola. Tira con delicatezza il cavo della ventola per sfilarlo dalla sua presa. Tira con delicatezza il cavo della ventola per sfilarlo dalla sua presa.
    • Usa la punta di uno spudger per ribaltare l'aletta di bloccaggio del connettore ZIF della ventola.
    • Tira con delicatezza il cavo della ventola per sfilarlo dalla sua presa.
    my cable was glued, had to be pryed up first.
    maccentric - Replica
    I found it a bit difficult to know exactly when the new one is back in position.
    steffen - Replica
    Take a close look at the spacing in the 3 photos. You essentially just flip the tab 90 degrees to stay vertical, then you pull the cable carefully out. When putting the new one in, no need to press hard. Just a little bit so you have that 2-3 mm spacing and then flip the tab back down.
    Daniel - Replica
  13. Svita le seguenti viti che fissano la ventola alla scocca superiore:
    • Svita le seguenti viti che fissano la ventola alla scocca superiore:
    • Una vite Torx T5 da 5,0 mm
    • Due viti Torx T5 da 3,6 mm
    When reinstalling, do the screw closest to the front of the computer first.
    Steve Wechsler - Replica
  14. Solleva il bordo della ventola più vicino alla cerniera dello schermo e rimuovi la ventola dal case superiore. Solleva il bordo della ventola più vicino alla cerniera dello schermo e rimuovi la ventola dal case superiore. Solleva il bordo della ventola più vicino alla cerniera dello schermo e rimuovi la ventola dal case superiore.
    • Solleva il bordo della ventola più vicino alla cerniera dello schermo e rimuovi la ventola dal case superiore.
    Um, this guide should include steps for applying thermal paste, including instructions to clean the mating surfaces, and pictures showing how much thermal paste to use.
    TheIronGiant - Replica
    Hi @theirongiant, there are generic thermal paste application instructions linked in the introduction “Don't forget to follow our thermal paste application guide before you reinstall your heat sink.”
    Sam Goldheart -
    Make sure to put the end furthest away from the hinge under the ribbon cable first.
    Then place the hinge side. The screw furthest away from the hinge is partially obscured by the ribbon cable.
    If not placed correctly, ribbon cable damage may result.
    toodarkpark - Replica
    Thanks to toodarkpark, it’s the priority to connect the cable of Fan before place it on position completely.
    If reverse the step, it will become ALMOST IMPOSSIBLE to insert the cable.
  15. Svita le due viti Torx T5 da 2,1 mm che fissano la copertura del cavo della scheda I/O alla scheda madre. Rimuovi la copertura del cavo della scheda I/O.
    • Svita le due viti Torx T5 da 2,1 mm che fissano la copertura del cavo della scheda I/O alla scheda madre.
    • Rimuovi la copertura del cavo della scheda I/O.
  16. Usa la parte piatta di uno spudger per sollevare il connettore della scheda I/O dalla sua presa sulla scheda madre. Stai attento a fare leva solo sul connettore della scheda I/O e non sulla presa o rischi di danneggiare la scheda madre.
    • Usa la parte piatta di uno spudger per sollevare il connettore della scheda I/O dalla sua presa sulla scheda madre.
    • Stai attento a fare leva solo sul connettore della scheda I/O e non sulla presa o rischi di danneggiare la scheda madre.
  17. Solleva il cavo della scheda I/O dalla scheda madre e piegalo in modo che non possa interferire con la scheda madre. Per evitare di danneggiare il cavo, piegalo dove è già piegato, all'estremità vicina alla scheda I/O.
    • Solleva il cavo della scheda I/O dalla scheda madre e piegalo in modo che non possa interferire con la scheda madre.
    • Per evitare di danneggiare il cavo, piegalo dove è già piegato, all'estremità vicina alla scheda I/O.
  18. Usa la punta di uno spudger per sollevare il connettore dello speaker destro dalla sua presa sulla scheda madre. Usa la punta di uno spudger per sollevare il connettore dello speaker destro dalla sua presa sulla scheda madre.
    • Usa la punta di uno spudger per sollevare il connettore dello speaker destro dalla sua presa sulla scheda madre.
  19. Usa la punta di uno spudger per spingere entrambi i lati del connettore della scheda I/O per sfilarlo man mano dalla sua presa sulla scheda madre. Usa la punta di uno spudger per spingere entrambi i lati del connettore della scheda I/O per sfilarlo man mano dalla sua presa sulla scheda madre.
    • Usa la punta di uno spudger per spingere entrambi i lati del connettore della scheda I/O per sfilarlo man mano dalla sua presa sulla scheda madre.
    Having a hard time at this step. Any suggestions? it's just not walking out.
    Moki - Replica
    Use your fingernails to pinch the sides of the clip inwards to release the connector. I couldn’t walk it out either, both sides needed to be pushed in simultaneously to pull it out of the socket.
    Do not pull from the cables end. you will risk separating thin cables from connector head. Use spudger tip to push it out.
    lamajr - Replica
  20. Usa la parte piatta di uno spudger per scollegare il cavo della retroilluminazione della tastiera dalla scheda madre e piegalo da parte dove non possa interferire con la scheda madre. Usa la parte piatta di uno spudger per scollegare il cavo della retroilluminazione della tastiera dalla scheda madre e piegalo da parte dove non possa interferire con la scheda madre. Usa la parte piatta di uno spudger per scollegare il cavo della retroilluminazione della tastiera dalla scheda madre e piegalo da parte dove non possa interferire con la scheda madre.
    • Usa la parte piatta di uno spudger per scollegare il cavo della retroilluminazione della tastiera dalla scheda madre e piegalo da parte dove non possa interferire con la scheda madre.
  21. Prendi l'aletta di plastica nera del connettore del cavo dello schermo e tirala per sbloccare il cavo e sfilalo dalla sua presa parallelamente alla scheda madre. Prendi l'aletta di plastica nera del connettore del cavo dello schermo e tirala per sbloccare il cavo e sfilalo dalla sua presa parallelamente alla scheda madre. Prendi l'aletta di plastica nera del connettore del cavo dello schermo e tirala per sbloccare il cavo e sfilalo dalla sua presa parallelamente alla scheda madre.
    • Prendi l'aletta di plastica nera del connettore del cavo dello schermo e tirala per sbloccare il cavo e sfilalo dalla sua presa parallelamente alla scheda madre.
  22. Sfila attentamente il connettore dell'ingresso DC dell'alimentazione dalla sua presa tirandolo parallelamente alla scheda madre. Sfila attentamente il connettore dell'ingresso DC dell'alimentazione dalla sua presa tirandolo parallelamente alla scheda madre.
    • Sfila attentamente il connettore dell'ingresso DC dell'alimentazione dalla sua presa tirandolo parallelamente alla scheda madre.
  23. Infila la parte piatta di uno spudger sotto il cavo dello speaker sinistro vicino al suo connettore e fai leva per sollevarlo, quindi piega il cavo da parte in modo che non dia fastidio. Infila la parte piatta di uno spudger sotto il cavo dello speaker sinistro vicino al suo connettore e fai leva per sollevarlo, quindi piega il cavo da parte in modo che non dia fastidio. Infila la parte piatta di uno spudger sotto il cavo dello speaker sinistro vicino al suo connettore e fai leva per sollevarlo, quindi piega il cavo da parte in modo che non dia fastidio.
    • Infila la parte piatta di uno spudger sotto il cavo dello speaker sinistro vicino al suo connettore e fai leva per sollevarlo, quindi piega il cavo da parte in modo che non dia fastidio.
  24. Se presente, rimuovi il nastro sopra il connettore ZIF del cavo del microfono. Se presente, rimuovi il nastro sopra il connettore ZIF del cavo del microfono.
    • Se presente, rimuovi il nastro sopra il connettore ZIF del cavo del microfono.
  25. Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF del cavo del microfono. Sfila il cavo del microfono dalla sua presa sulla scheda madre. Sfila il cavo del microfono dalla sua presa sulla scheda madre.
    • Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF del cavo del microfono.
    • Sfila il cavo del microfono dalla sua presa sulla scheda madre.
  26. Se presente, rimuovi il nastro sopra il connettore del cavo della tastiera. Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF. Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF.
    • Se presente, rimuovi il nastro sopra il connettore del cavo della tastiera.
    • Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF.
  27. Sfila il cavo della tastiera dal suo connettore ZIF sulla scheda madre. Sfila il cavo della tastiera dal suo connettore ZIF sulla scheda madre.
    • Sfila il cavo della tastiera dal suo connettore ZIF sulla scheda madre.
  28. Se presente, rimuovi il nastro che copra il connettore del cavo del trackpad. Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF. Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF.
    • Se presente, rimuovi il nastro che copra il connettore del cavo del trackpad.
  29. Sfila il cavo a nastro del trackpad dalla sua presa sulla scheda madre. Sfila il cavo a nastro del trackpad dalla sua presa sulla scheda madre.
    • Sfila il cavo a nastro del trackpad dalla sua presa sulla scheda madre.
    I didn’t pay enough attention when I pulled the ribbon cable out, so trying to figure out how to reattach it was quite challenging for me. After searching unsuccessfully for videos/instructions on how to reattach, I finally figured out that the ribbon cable goes UNDER the black plastic part of the socket (closest to the ribbon), and then you push the little tab down to hold it in place. Hope this helps others who are struggling with this part. Otherwise, this was an amazing tutorial, and saved my macbook…
    CRI - Replica
  30. Svita le cinque viti Torx T5 da 3,5 mm che fissano la scheda madre alla scocca superiore.
    • Svita le cinque viti Torx T5 da 3,5 mm che fissano la scheda madre alla scocca superiore.
    • Durante il rimontaggio avvita leggermente le cinque viti, posiziona correttamente la scheda madre e quindi serra le viti uniformemente.
  31. Solleva leggermente il bordo vicino al processore della scheda madre e tiralo verso l'alloggio della ventola per sfilare le porte dalla scocca superiore. Rimuovi la scheda madre. Durante il rimontaggio assicurati che i cavi  della tastiera, della retroilluminazione della tastiera, del MagSafe e del microfono non si impiglino sotto la scheda madre.
    • Solleva leggermente il bordo vicino al processore della scheda madre e tiralo verso l'alloggio della ventola per sfilare le porte dalla scocca superiore.
    • Rimuovi la scheda madre.
    • Durante il rimontaggio assicurati che i cavi della tastiera, della retroilluminazione della tastiera, del MagSafe e del microfono non si impiglino sotto la scheda madre.
    • Assicurati anche di infilare le prese delle protezioni EMI sotto il bordo della scocca e non sopra.
  32. Svita la vite Torx T5 da 2,9 mm che fissa l'SSD alla scheda madre.
    • Svita la vite Torx T5 da 2,9 mm che fissa l'SSD alla scheda madre.
    It looks like this picture is not a 820-4924-A motherboard (A1502 2015 13in. MBPr). It must come from a previous version of Macbook pros. Don’t panic if the RAM chips on the top right corner do not look exactly the same on your board and on this picture.
    Mipam - Replica
    The screw on my disk is ruined, i cant remove it, any suggestions?
    dieyoung79 - Replica
  33. Solleva leggermente l'estremità libera dell'SSD e sfila l'unità dalla sua presa tirandola parallelamente alla scheda madre. Solleva leggermente l'estremità libera dell'SSD e sfila l'unità dalla sua presa tirandola parallelamente alla scheda madre. Solleva leggermente l'estremità libera dell'SSD e sfila l'unità dalla sua presa tirandola parallelamente alla scheda madre.
    • Solleva leggermente l'estremità libera dell'SSD e sfila l'unità dalla sua presa tirandola parallelamente alla scheda madre.
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 74 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Sam Goldheart
Membro da: 18/10/2012
449.850 Reputazione
548 Guide realizzate
iFixit Membro di iFixit
Community
142 Membri
16.794 Guide realizzate
9 Commenti
This guide helped me repair my MacBook Pro with no prior knowledge of working on computers. I purchased a new logic board after mine broke from eBay, from a seller named L2 Computer Inc. and followed this guide using the iFixit pro tech tool kit and their thermal compound application set to reinstall the heat sink, and my computer turned on right away. Everything was so easy using this guide. The pictures are so good at showing how to do the steps, and the tool kit had really nice tools which made the whole process very simple. I am so thankful that you all help people fix their computers. It could not have been easier with this guide. It’s very well-written.
COURTNEY DYE - Replica
Help me fix my MacPro. You are so good, Showing step by step. Make it very simple. Very thankful helping other sharing your skill. Tony, October, 2018
smelltony - Replica
Great guide. Had issues with my Late 2013 MBP and narrowed it down to the logic board. I replaced it with a Mid-2014 MBP logic board as they are interchangeable thanks to this detailed guide. Laptop now fixed and upgraded!
velocity211 - Replica
I can’t say enough about how well done this guide is for replacing a late 2013 MacBook logic board. The step by step with pictures were professional and spot on. I had a 4GB, i5 that had got to the point where I had to keep using a memory app to free up memory every couple minutes. Not being able to upgrade memory I was left with little options other than to buy a new one. After finding this site, I got a new logic board with i7 and 16GB of memory, I was able to turn my crippling MacBook back into a robust laptop I can once again enjoy using hopefully for at least a few more years. Bought the tools on here to complete the replacement and everything went without a hitch.
So a BIG thank you, thank you, thank you.. Keep up the great work on this site.. I know I’ll be back to check in on what’s available and when I have something else that needs to be fixed/upgraded vs buying new. :)
Boston222
Ted - Replica
@boston222 I am in a similar situation where my 4GB memory is killing me. Would you be able to let me know where you got your i7 with 16GB of memory? I have been looking but I cannot find an i7 .. all I find is i5 with 16GB of memory .. I would appreciate if you could provide a website or model number of the item you ordered so I could get the same one.
Thanks in advance!
Hari -
After replacing the Logic Board, is there any other steps afterwards with programing? After I replaced the board, the flashing question mark comes up. When I go into Disk Utility the HD is not showing up. If anyone has any input I would appreciate the help.
Subhi Saleh - Replica
i have same problem did you solve it?
Itay Israeli -
After replacing my logic board, it worked for a while then I started getting crashes followed by three beeps on boot up. Anyone got any ideas? I want back over and checked that all connectors were ok. Have I purchased a dodgy logic board from eBay?
patrick houston - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 82
Ultimi 30 Giorni: 378
Tutti i Tempi: 81,098
