Introduzione
This repair guide was authored by a member of the iFixit community and hasn’t been endorsed by Google. Learn more about our repair guides here.
This guide will show you how to replace a Google Pixel motherboard. If you're having issues with the overall functionality of your phone and are unable to diagnose the root cause, consider replacing the motherboard of your device.
Cosa ti serve
Turn off the device.
Prepare an iOpener to heat the edges of the display and soften the adhesive underneath. Alternatively, you may use a heat gun or a hair dryer.
Attrezzo utilizzato in questo passaggio:Suction Handle$2.99
Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
You may need to apply more heat if this doesn't come up. Don't be impatient, this will take time. Once you can gently insert a tool in the gap, move on to the next step.
Attrezzo utilizzato in questo passaggio:iFixit Opening Picks (Set of 6)$4.99
With the adhesive cut, slowly lift the display up from the top (the side with the speaker-grille cutout), carefully flip it over vertically toward the bottom of the device, and rest it on its face, as shown.
Use a T5 Torx driver to remove the nine 3.5 mm screws securing the midframe.
Use a SIM ejection tool to remove the SIM card tray located at the top left of the device.
Use a spudger to pry up the black and white coaxial cables attached to the upper right and left-hand sides of the motherboard.
Altre 12 persone hanno completato questa guida.
2 Commenti
Where do you buy a new motherboard?
Look for a donor phone from used markets, I don't believe the motherboard itself was ever sold individually.
(I'm not 5 years late, you're 5 years early)
Noah -
