Salta al contenuto principale
Toshiba NB205 N330PK RAM Replacement
Cosa ti serve
  1. Toshiba NB205 N330PK RAM Replacement, RAM: passo 1, immagine 1 di 2 Toshiba NB205 N330PK RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. Toshiba NB205 N330PK RAM Replacement: passo 2, immagine 1 di 3 Toshiba NB205 N330PK RAM Replacement: passo 2, immagine 2 di 3 Toshiba NB205 N330PK RAM Replacement: passo 2, immagine 3 di 3
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Toshiba NB205 N330PK RAM Replacement: passo 3, immagine 1 di 2 Toshiba NB205 N330PK RAM Replacement: passo 3, immagine 2 di 2
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  4. Toshiba NB205 N330PK RAM Replacement: passo 4, immagine 1 di 2 Toshiba NB205 N330PK RAM Replacement: passo 4, immagine 2 di 2
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
Conclusione
Mason McCaskill
Membro da: 10/18/13
1.021 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 559
