Introduzione
Vai al passo 1 ↓Se la spazzola rotante non gira, controlla la cinghia rotante per vedere se devi sostituirla. L'aspirapolvere si accenderà comunque, ma la spazzola non girerà se la cinghia è rotta.
Cosa ti serve
Ricambi
Strumenti
Tira il manico mentre premi il tasto di rimozione per rimuovere il corpo dell'aspirapolvere.
Rimuovi la cinghia rotante da attorno alla spazzola rotante e alla trasmissione del motore.
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Altre 34 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
31Commenti sulla guida
Very helpful re shark vacuum , thank you!
First of all, I couldn’t find the belt at 3 different stores that sell the vacuum including the place I bought it. Not on their websites either. And not on Shark’s website. Strange. I got it from Amazon. Next, I cannot get at the roller as the housing won’t come apart even with brute force. And yes, I got all the screws out and followed all instructions. It just fits so tightly, I cannot get it apart. I have a $350 vacuum, an $8 belt, and I cannot vacuum my rugs. Really disappointed as I’ve replaced belts in other vacuums in the past with no problems. And I’ve had this vacuum for a relatively short time and use it only weekly in a fairly small condo. Not sure why the belt literally disintegrated and came out in pieces.
The number of screws in the instructions is not correct. There were 11 in mine. One that is deeper and my screw driver didn't reach. But since I was just trying to clean the roller I gave up. But I'm betting you still need a screw or two out if you only took out the number listed. good luck. P.S. sometimes something you vacuum up gets in just the wrong spot and eats the belt by rubbing. The heat disintegrates it.
