Introduzione
Segui questa guida per sostituire il tuo alimentatore.
Cosa ti serve
Capovolgi la PS3 e poggiala sulla parte superiore.
Facendo attenzione, rimuovi l'adesivo di garanzia presente nella parte sottostante della console per trovare la copertura di una vite nascosta.
Rimuovi le 4 viti Torx da 13,3 mm sotto l'apertura del drive Blu-Ray (alcuni modelli possono avere solo 3 viti).
Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening.
Can we edit this to say 4 screws?
I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
Robert -
My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
How do u buy the screw driver for these screws
Online at the usual suspects?
Or some hobby stores or places that sell tools will sometimes carry these.
Anyone else's screws for this step need the T7 bit instead of T8?
What is the name of this screwdriver
Solleva la cover superiore dal suo bordo posteriore e ruotala verso la parte anteriore della PS3 (dove presenti i tasti ON/OFF e EJECT}.
Rimuovi la cover superiore del PS3.
Premi la leva di bloccaggio del connettore del cavo di alimentazione AC e tiralo verso l'alto per scollegarlo dall'alimentatore.
Tira verso l'alto il connettore del cavo di alimentazione DC per scollegarlo dalla sua presa sull'alimentatore.
Svita le due viti a croce Phillips da 7,6 mm che fissano l'alimentatore alla scocca inferiore.
Question: if a screw doesn't come out, what do you recommend, without potentially damaging the system, inside and out?
It seems these can be quite tight, but they did come loose with someextra force in my case. They did that thing where it makes cracking sounds, but nothing really breaks. They're just really tight in there. - I just wouldn't recommend taking these out too often.
The screwdrivers on the guide didn't work mine just don't come out any tips model is slim CECH 2001A
Step 8
These screws work as a ground pass through between the motherboard shields and the power supply. My cousin took his PS3 to a repair shop to replace the power supply, they didn’t put the screws back in after that and the PS was shutting down suddenly (no light green or red), put a couple of new screws and it’s being working fine since
Sometime ago i took apart my PS3 out of curiosity, When puting it back together, i messed it up, I stripped one of the PSU screws. Now, i can't take it apart for a paste replacement. Any ideas?
I had the same problem with very tight screws on PS3 power supply. I solved it by purchasing a Screw removal / extractor gripping pliers long nose style , with unique non-slip jaws for quickly extracting damaged / stuck screws. ENGINEER PZ-60 Neji-Saurus,Silver. ( bought mine on Amazon)
These pliers have special grips on tapered end to hold and turn stripped or rusty screws. It took a lot of effort, but screws finally came out using these pliers. A bit of sewing machine oil and prising under the washers with a flat screwdrvers helps too. Failing that, take it to repair shop as they are VERY TIGHT screws on some models of PS3.
I need some advice I have taken apart my PS3 slim unit to clean it. I bought it second hand last year and it is filthy, I am having issues because the screws holding down the power supply are very tight, they are not stripped and I am using the right screwdriver. I don’t want to damage the screws, can anyone help?
Continua a sollevare il bordo sinistro dell'alimentatore finché supera le due barre in metallo mostrate nella seconda immagine.
Rimuovi l'alimentatore dalla PS3, stando attento a non impigliarlo in dei cavi.
It seems it kind of ends for me here. I can only lift the left side about an inch and then the right side stays down like it’s stuck to something underneath. It feels like I’m bending something. Could something have melted underneath?… It's really stuck, I can't get it to come loose. And I can't see much shining a light into it either. - Any tips?…
Did you undo the screws?
I had the same issue but was able to get it off. The right side (as per the above picture) has two long column like sections that actually goes into the machine. Took me a bit of wiggling and some brute force.
Um, I translated the guide from French to English and the name of the guide was “Food” and the description said “This guide shows you how to replace your diet” The translation is incorrect just to let you know!
Hi! Thanks for you attention! But no worries, the French word “alimentation” means power, food or diet depending the context.
Alright, thanks!
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 61 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
11 Commenti
Hello, my question is I have an american ps3 which works on 110 volts and I'm in europe where they use 220volts so if I plug my ps3 without any converters will it burn or will it wor? Because I have a laptop and it works fine will my ps3 work like that aswell?
Perhaps, you should check the model of your PS3 and verify online. I have the CECH-2501B model (110v) but I use it in Nigeria (220v).
N3RVE -
Need help with console or trouble shooting the problem I am in the repair and purchased used or damage consoles even get it In way I can be able to talk to people who is looking for trouble shooting on phone or email or u to choose. But any console or device I am interested in buying it so I have it on hand I have seen people pay way more 4 the part. Wene it is sometimes. New or used Console r cheaper to get the whole different devices then part for the console
More to my comment I can be able to talk or text or email. SO you can do it yourself and it's not to bad to diy and your up to run the console after u fixed it. Do I you self. (Diy) even if people walk through it step 4 step.
My ps3 2501A was dropped while moving now it wont show up o the screen or turn off .. What can it be ?
Hello i was moving and my ps3 slim 2501A was dropped now it wont show up on the screen nor will it connect on hdmi or usb or anythig and it wont turn off alone what can it be?
i have a ps3 i bought it from the uk and i am in the usa the ps3 is 220 ait wont stay one what should i do, should i buy a 110-220 power supply
My PS3 cech 2001a has quit powering on after I opened it to retrieve a stuck game disk what should I do now
Not sure if this is where I should post this, I have a ps3 it turns on and the light goes green for 10 seconds and then it just shuts down. Not sure whats wrong with it any help would be great.
Don’t even need to bother with the sticker anymore since SONY does not care what you do with them anymore.
Travis Wheeler - Replica
