Salta al contenuto principale
Sony-BDP-SX1000 Battery Replacement
Cosa ti serve
  1. Attenzione: i passaggi 1-2 provengono da una guida contrassegnata come in corso.
    Sony-BDP-SX1000 Battery Replacement, How To Open The Device: passo 1, immagine 1 di 2 Sony-BDP-SX1000 Battery Replacement, How To Open The Device: passo 1, immagine 2 di 2
    • Flip the Sony BDP-SX1000 over so that the underside is facing up.
    • Remove the four 2mm Phillips #0 screws at the top of the device.
    • Remove the rest of the J0mm Phillips #0 screws from the device.
  2. Sony-BDP-SX1000 Battery Replacement: passo 2, immagine 1 di 2 Sony-BDP-SX1000 Battery Replacement: passo 2, immagine 2 di 2
    • Take out the seals at the bottom and at the corners with edge of screwdriver. Remove the J0mm Phillips #0 screws under the seals.
    • Remove the back lid of the Sony BDP-SX1000 so that you can now see the inside of the device. The two lids are attached by two wires. The small wire on right side of the top lid goes on right side of bottom lid or on the black connector. The big wire on left side of the top lid goes on left side of the bottom lid or on white connector.
  3. Sony-BDP-SX1000 Battery Replacement, Battery: passo 3, immagine 1 di 2 Sony-BDP-SX1000 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • The battery can be found at the bottom of the device.
    • Remove the battery by removing the white connector.
Conclusione
UC Davis, Team S4-G2, Lore Fall 2018 Membro di UC Davis, Team S4-G2, Lore Fall 2018
UCD-LORE-F18S4G2
3 Membri
3 Guide realizzate
Un commento
Any one know where to find replacement batteries?
ledude71 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 978
