Salta al contenuto principale
Sony ZS-RS60BT Repair Battery Replacement
Cosa ti serve
  1. Sony ZS-RS60BT Repair Battery Replacement, Battery: passo 1, immagine 1 di 2 Sony ZS-RS60BT Repair Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Locate back panel.
    • Put firm downward pressure on the panel until it slides off.
  2. Sony ZS-RS60BT Repair Battery Replacement: passo 2, immagine 1 di 1
    • If the batteries are corroded, it is recommended to wear gloves when removing the batteries.
    • From the positive side of the battery, push it to the negative side and lift up.
    • Repeat for each battery until the compartment is empty.
Conclusione
Baylor, Team 8-2, Whitney Spring 2017 Membro di Baylor, Team 8-2, Whitney Spring 2017
BU-WHITNEY-S17S8G2
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 664
