Parti
Nessuna parte richiesta.
  1. Press down the release button on the bottom left corner of the face plate. Then remove the face plate carefully. Then remove the face plate carefully.
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Unscrew the four (length - 11.11mm) phillips-head screws on the front screen.
    • Unscrew the four (length - 11.11mm) phillips-head screws on the front screen.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Use two fingers to create a small gap on the top of the faceplate, as indicated in the picture. Use two fingers to create a small gap on the top of the faceplate, as indicated in the picture. Use two fingers to create a small gap on the top of the faceplate, as indicated in the picture.
    • Use two fingers to create a small gap on the top of the faceplate, as indicated in the picture.
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen. Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Please refer to the iFixit soldering guide for help removing the LCD screen.
Conclusione
Kyle
Membro da: 10/10/2011
114 Reputazione
2 Guide realizzate
Cal Poly, Team 5-35, Amido Fall 2011 Membro di Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Membri
8 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,846
