Press down the release button on the bottom left corner of the face plate.
  • Press down the release button on the bottom left corner of the face plate.
  • Then remove the face plate carefully.
Aggiungi Commento
Aggiungi Commento
  • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
  • Remove side-metal plates gently.
  • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
Aggiungi Commento
  • Remove the black front plate of the stereo.
Aggiungi Commento
  • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
  • Lift off the top plate.
Aggiungi Commento
  • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
  • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
  • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
Aggiungi Commento
  • Carefully pull the fuse out of the back of the stereo.
Aggiungi Commento
  • Firmly grip the body of the stereo and pull off the silver back plate.
Aggiungi Commento
Aggiungi Commento
  • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
Aggiungi Commento
  • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
  • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
Aggiungi Commento
  • Using the Phillips #0 Screwdriver, unscrew the two gold screws (length - 7.37mm) found on top of the CD Tray.
  • Remove the top cover.
Aggiungi Commento
  • These two pieces will NOT separate completely. They are connected by small wires on one side. So make sure you follow the pictures carefully to know which side to pull up.
  • Grip the top of the CD-Drive and pull it up and over, as shown in the pictures.
  • Notice the wires that hold the two pieces together.
Aggiungi Commento
  • Pay extra attention to the spring inside the CD-Drive. This will be crucial for the next step.
  • Slowly pull up the side opposite the spring, but make sure not to over-stretch the spring. This could damage the device.
  • While the part is lifted, remove your jammed CD, and you are finished!
Aggiungi Commento
Conclusione
Kyle
Membro da: 10/10/2011
100 Reputazione
2 Guide realizzate
Cal Poly, Team 5-35, Amido Fall 2011 Membro di Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,297
