Introduzione
Make sure you can explore the Xplod very well.
Cosa ti serve
Press down the release button on the bottom left corner of the face plate.
Then remove the face plate carefully.
Attrezzo utilizzato in questo passaggio:Phillips #0 Screwdriver$5.49
Using the Phillips #0 Screwdriver, unscrew the 3 screws (length - 7.5mm) on the front of the device.
Attrezzo utilizzato in questo passaggio:Phillips #1 Screwdriver$5.49
Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
Remove side-metal plates gently.
Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
Lift off the top plate.
Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
Using the Phillips #0 Screwdriver, unscrew the 4 dark-silver screws (length - 3.71mm).
Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
To remove the Audio In/Audio Out inputs on the circuit board please refer to the iFixit soldering guide to assist you.
