Introduzione
A common problem occurring in the ZL is that the phone will sometimes attempt to draw significant current from the battery, immediately shutting down the phone. Replacing a worn battery with a new one should help to reduce this problem, even if only temporarily (and by temporarily this could mean any number of months)
BEFORE READING THIS GUIDE, please be aware that by removing the backing of this phone, you are essentially REMOVING THE MOISTURE SEALS protecting your phone. No more dumping this one in water unless you want to get out the silicone gun and have some fun with it
Cosa ti serve
We will be removing components from the back of the phone; the battery is sandwiched between the motherboard and the screen so it's right in the middle of everything
The service cover is easily visible from the back of the phone. There is an indentation to put a finger nail/spudger to pry upward
There are 2 screws located underneath the label that shows where your sim card/microSD card go. Pry the label upwards to gain access.
Remove the 2 #0 Philips screws securing the back of the case to the frame. The #0 screwdriver is the only one that will be needed for completion of this repair.
Start with your thinnest opening tool (mine happens to be a sharpened guitar pick) and insert it between the back casing and the frame. You should hear the sound of adhesive letting go.
Use a heavier plastic opening tool or spudger inside the gap that you began to open up, sliding it further down each side of the case.
There are 3 plastic clips on one side and 2 on the other; in these areas you will have more resistance when sliding/prying. Slowly apply more pressure and they should release with a click
All of the ribbon cables listed will need to be removed - thankfully, they are all snap connectors, meaning they simply lift off of the motherboard to disconnect
Removal of the top 4 snap connectors is straightforward - on the right side of each connector, insert a prying tool and pry upwards. The battery cable (right corner) requires slightly more force
Look at picture 2 and 3 - bend the NFC antenna (thin black piece) upwards to reveal copper tape bridging the connector and the motherboard metal. Peel this up from the connector
Straightforward removal, see top 4 (red) connectors
Pry from underneath where the wires are. Shouldn't take too much force, but it is small and likely brittle so be careful
Remove the 2 screws that secure the charging port bracket (silver clip shown)
Remove metal bracket by lifting from circuitry-side (as shown). There is mild adhesive securing it to the charging port; don't be surprised if additional force is needed
Remove the black screw located just underneath the rear-facing camera
Insert your spudger as shown. This will involve some pressure, but the right side of the module should begin to lift from the frame
My hand was covering the exact entry point, but you will want to further separate the module from the top left side of the phone (I'm holding it upside down)
Be very careful when lifting from the third spot - you only want to separate the clips on the side, if you lift the entire piece out of the phone, you can easily rip a ribbon cable underneath the assembly. See the next step for directions on how to fully remove the module
The top-left flex cable is the culprit for the added difficulty of fully separating the two pieces. But, since the adhesive is relatively small (see 2nd photo), by lifting the connector at a 90 degree angle away from the phone at a slow, steady pace, it should disconnect without damaging either cable
Notice how much adhesive is holding the ribbon cable against the phone, but do not judge its effect by its size, or you may lose some critical phone functions!
This is the flex cable that is likely to tear if you are not careful when removing the connectors from the adhesive. I believe it is the proximity sensor cable, which turns the screen off when you have your face close to the phone (during a phone call)
The battery is in sight! - keep in mind that without a heat gun (or very least hair dryer), this step will be impossible, as the adhesive that secures the battery to the back of the phone is very strong
Before removing the battery, make sure that the two ends connecting the battery to the frame have been disconnected from the frame
You can keep the majority of the tape on the battery untouched, but eventually you will have to take it completely off the old battery and transfer onto the new one.
While the phone is still warm/hot (and don't burn your hands), insert a guitar pick/opening tool underneath the battery around the top. some force will be needed
If you've made it this far underneath the battery, the temperature has likely cooled down significantly. So, keeping the opening tool inside, you'll be heating the battery again. This may deform your opening tool if it is made of plastic, so use your least-favorite one
Once again, heat the battery area uniformly until it is warm/hot to the touch
Insert a second opening device around the area of the first, but moving towards the corner of the battery, in an attempt to begin separating from the side
Push your opening tools as far as you can and pry upwards. Repeat the heating process if necessary, and with enough love and care, the battery should release. In the third picture, you can see the areas that adhere the battery to the case
On the old battery, fully remove the copper tape that grounds the phone. It isn't terribly delicate, but it is definitely breakable. My recommendation is to use tweezers, but careful fingers should be fine
Even if it's bent, as long as it's still intact, it should work with the new battery. Once the new battery is inserted, place the tape over the contact and the screw inlet, and simply flatten the remainder of the tape against the battery
The new battery that I purchased fit very snugly inside the phone. Make sure that the battery is not bent while inserting, although you may have to apply some pressure to get it right inside.
With the new battery secured in place, you can now begin reassembly. With all of your previous experience, this shouldn't take more than 15 minutes at most.
Altre 28 persone hanno completato questa guida.
30 Commenti
Guide was precise to the point. Very well described. Thanks for this guide.
Thanks a lot for the super detailed process. Amazing work. I was disappointed when sony service center refused to replace the battery of the phone, saying that this model is "non repairable". Your article gives me hope for my phone. I will look for a local technician as I'm not confident enough that I'll won't screw up my phone. Thanks again for this wonderful article
Recognizing limitations is a big part of repair. At least having the information gives you an idea of what you're getting into.
Mark -
Just as perfect as any guide can be. I read it twice, and felt very confident that I can do it. Replaced the battery of ZL on my own, after Service Center refused. Feeling proud on myself, but again, it wouldn't have been possible without this guide. Thank you so much.
where can i get a new battery for xperia ZL?
I know this is probably no longer relevant, but for others your best bet is likely to use eBay. The price was medium-high in comparison to similar phones.
Mark -
Excellent, I have just now replaced and works fine!!!
You don't need the heat gun if you pry carefully. Just don't put pressure against the inside of the screen. (Under the battery.)
Jeremy's right, but I get the feeling he was very careful. The adhesive on the phone I worked on was fairly strong, and you can never go wrong with warming adhesive. Even if you only have a hair dryer, warming to 40-50 degrees Celsius can go a long way in preventing accidental damage. Lithium Polymer batteries should not be bent, as they can potentially explode (worst case scenario, but still).
Mark -
Thank you so much for the details on the explanation. I'm trying to replace the screen of my wife's ZL. Do you have more infrmation or suggeestions on any other guide or viedeos to check them as reference guides???
Thnaks again
There were very few resources available at the time that I created this guide. If you found some that were useful, it might not hurt to list them so that others can see them too.
Mark -
hi and thank you.......but the Loudspeaker Disassemble and is being hot....please help
I apologize but this phone did not belong to me, and as such I can't do any real diagnostic. Internally, this phone could definitely get toasty if it was being used for games. The loudspeaker itself draws very little power, so check for any shorts while putting it back together. Other than that, good luck and list your solution if you find one.
Mark -
Hi Mark, i have two issues
1. During step.7, one screw i cant remove with the same screw driver i am using for all other screws.
2. i seem to have ripped off the ribbon cable you cautioned during step.8, is there any way out from this :(. Will the phone still work with reduced functionality with this cable gone ?
Incredible detailed guide! Gave the ZL of my wife a second life. Now she hates me, because there's no need anymore for a new one! :)
Happy to ...be of service. I think. Carry on!
Mark -
This guide is stunning! I was worried if heating up the battery can be done without letting the whole thing explode (haha) but using a hair dryer and heating it up 4 or 5 times while using the guitar pick to slowly unstick the battery from the bottom (took about half an hour) works verry well. Take your time for this step! Reassembling was easy and my girlfriends phone is now working again. Mark you made two persons verry happy today. Thank you!
Thank you so much. Just finished it! (and suggested some additions)
Vielen Dank, mit Hilfe dieser präzisen Anleitung habe ich es tatsächlich locker geschafft, das XperiaZL zu reparieren! Alles Wichtige ist angesprochen bzw. bebildert, dann braucht es nur noch etwasZeit und eine ruhige Hand .
Nochmals vielen Dank !!!
I could be wrong, but it seems to be on the right side of the phone somewhere (power button side). I don't have the phone anymore to confirm. Look for a small hole in the side of the case. If it's not there, it would likely be on the top.
Mark -
After spending many hours dealing with you tube videos and incomplete/inaccurate information, I finally encountered someone whao knows what they are talking about. True---I could have run off to some tech expert to fix my problem---but isn't there more than enough of this kind of dependency? I would rather do it myself, then I would have the knowledge to apply next time, something I would not have if I turned to an expert.
Thanks to your tutorial now my ZL is back on track. The only thing I screwed up was the notification light on the bottom. Do you know which connector I have to look for? Thank you anyway!
Thank you very much for this excellent guide. I've just changed the battery of my ZL for the second time using your instructions and everything went well. Great job!
any idea where can we buy original xperia zl battery?
Ebay or Aliexpress would be my first stops. It’s not a particularly new phone, so stock might be harder to come by
Mark -
Is the Copper strip on the battery required? I don’t have mine on the dead battery that was in my phone as I bought it used
Grand merci pour ce guide pas-à-pas qui m’a été très utile: bonnes description/photos!
Thanks!
(Le seul soucis vient de ma “nouvelle baterie'“, elle ne vient pas de sony, et semble se décharger très rapidement!)
