Introduzione
Use this guide to remove or replace a broken or defective rear camera in a Sony Xperia Z5.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Cosa ti serve
Before you begin, switch off your phone.
Apply a heated iOpener to the edges on the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
